Hello! I am trying to add toolbars into map and table in FeatureTable-example from
https://developers.arcgis.com/javascript/3/jssamples/featuretable.html
<!DOCTYPE html>
<html>
<head>
<title>Using FeatureTable</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.18/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.18/esri/css/esri.css">
<script src="https://js.arcgis.com/3.18/"></script>
<style>
html, body, #map{
width:100%;
height:100%;
margin:0;
padding:0;
</style>
<script>
require([
"esri/layers/FeatureLayer",
"esri/dijit/FeatureTable",
"esri/geometry/webMercatorUtils",
"esri/map",
"dojo/dom-construct",
"dojo/dom",
"dojo/parser",
"dojo/ready",
"dojo/on",
"dojo/_base/lang",
"dijit/registry",
"dijit/form/Button",
"dijit/layout/ContentPane",
"dijit/layout/BorderContainer",
"dijit/form/TextBox"
], function (
FeatureLayer, FeatureTable, webMercatorUtils, Map,
domConstruct, dom, parser, ready, on,lang,
registry, Button, ContentPane, BorderContainer, TextBox
parser.parse();
ready(function(){
var myFeatureLayer;
var map = new Map("map",{
basemap: "dark-gray"
map.on("load", loadTable);
function loadTable(){
myFeatureLayer = new FeatureLayer("https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/Warren_College_Trees/FeatureServer...", {
mode: FeatureLayer.MODE_ONDEMAND,
visible: true,
outFields: [
"Collected", "Status", "Spp_Code", "Height", "Cmn_Name", "Sci_Name", "Street", "Native"
on(myFeatureLayer, "load", function(evt){
var extent = myFeatureLayer.fullExtent;
if (webMercatorUtils.canProject(extent, map)) {
map.setExtent( webMercatorUtils.project(extent, map) );
map.addLayer(myFeatureLayer);
myFeatureTable = new FeatureTable({
"featureLayer" : myFeatureLayer,
"outFields": [
"Collected", "Spp_Code", "Height", "Cmn_Name", "Sci_Name", "Native"
fieldInfos: [
alias: 'Species Code',
alias: 'Common Name',
alias: 'Scientific Name',
"map" : map
}, 'myTableNode');
myFeatureTable.startup();
on(dom.byId("homebutton"), "click", function(){
Fun1('1');
on(dom.byId("butbutton"), "click", function(){
Fun1('2');
function Fun1(Msg){window.alert(Msg);};
</script>
</head>
<body class="claro esri">
<div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="width:100%; height:100%;">
<div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center', splitter:true" style="height:50%">
<div id="navToolbar" data-dojo-type="dijit/Toolbar" data-dojo-props="region:'top'" >
<div data-dojo-type="dijit/form/Button" id="homebutton" >Home</div>
</div>
<div id="map"></div>
</div>
<div id="bot" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'bottom', splitter:true" style="height:50%">
<div id="navToolbarBot" data-dojo-type="dijit/Toolbar" data-dojo-props="region:'top'" >
<div data-dojo-type="dijit/form/Button" id="butbutton" >Some</div>
</div>
<div id="myTableNode"></div>
</div>
</div>
</body>
</html>
I have added toolbars with buttons but now I see excess scroll-bars. It's not good.
Then I changed ContentPane to BorderContainer and set property "region":
<div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="region:'center'" >
</div>
<div id="map" data-dojo-props="region:'center'"></div>
</div>
<div id="bot" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="region:'bottom', splitter:true, style:'height:200px'">
</div>
<div id="myTableNode" data-dojo-props="region:'center'"></div>
</div>
</div>
</body>
Now it looks better - without scroll-bars, but when I try to move splitter, bottom div run to top of screen.
Probably I don't understand something impotant.
