Tracy,
Here is a sample that adds a zoom to and save button to the attribute inspector:
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title>Editable FeatureLayer in Selection Only Mode with Attribute Inspector</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.12/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.12/esri/css/esri.css">
<style>
html, body {
height: 100%; width: 100%;
margin: 0;
padding: 0;
overflow: hidden;
#mapDiv{
margin: 0;
padding:0;
#detailPane{
height:20px;
color:#570026;
font-size:12pt;
font-weight:600;
overflow:hidden;
.dj_ie .infowindow .window .top .right .user .content { position: relative; }
.dj_ie .simpleInfoWindow .content {position: relative;}
.esriAttributeInspector {height:100px;}
.esriAttributeInspector .atiLayerName {display:none;}
.esriAttributeInspector .atiButton{
margin-top:1px;
margin-right:45px;
</style>
<script src="http://js.arcgis.com/3.12/"></script>
<script>
var map;
var updateFeature;
require([
"esri/map",
"esri/layers/FeatureLayer",
"esri/dijit/AttributeInspector",
"esri/symbols/SimpleLineSymbol",
"esri/symbols/SimpleFillSymbol",
"esri/Color",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/config",
"esri/tasks/query",
"dojo/query",
"dojo/parser",
"dojo/dom-construct",
"dijit/form/Button",
"dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
], function(
Map, FeatureLayer, AttributeInspector,
SimpleLineSymbol, SimpleFillSymbol, Color,
ArcGISDynamicMapServiceLayer, esriConfig,
Query,dojoQuery,
parser, domConstruct, Button
parser.parse();
// refer to "Using the Proxy Page" for more information: https://developers.arcgis.com/javascript/jshelp/ags_proxy.html
esriConfig.defaults.io.proxyUrl = "/proxy/";
map = new Map("mapDiv", {
basemap: "streets",
center: [-97.395, 37.537],
zoom: 11
map.on("layers-add-result", initSelectToolbar);
var petroFieldsMSL = new ArcGISDynamicMapServiceLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Petroleum/KSFields/MapServer");
petroFieldsMSL.setDisableClientCaching(true);
map.addLayer(petroFieldsMSL);
var petroFieldsFL = new FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Petroleum/KSFields/FeatureServer/0", {
mode: FeatureLayer.MODE_SELECTION,
outFields: ["approxacre", "objectid", "field_name", "activeprod", "cumm_oil", "cumm_gas", "avgdepth"]
var selectionSymbol = new SimpleFillSymbol(
SimpleFillSymbol.STYLE_NULL,
new SimpleLineSymbol(
"solid",
new Color("yellow"),
null
petroFieldsFL.setSelectionSymbol(selectionSymbol);
petroFieldsFL.on("edits-complete", function() {
petroFieldsMSL.refresh();
map.addLayers([petroFieldsFL]);
function initSelectToolbar(evt) {
var petroFieldsFL = evt.layers[0].layer;
var selectQuery = new Query();
map.on("click", function(evt) {
selectQuery.geometry = evt.mapPoint;
petroFieldsFL.selectFeatures(selectQuery, FeatureLayer.SELECTION_NEW, function(features) {
if (features.length > 0) {
//store the current feature
updateFeature = features[0];
map.infoWindow.setTitle(features[0].getLayer().name);
map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint));
else {
map.infoWindow.hide();
map.infoWindow.on("hide", function() {
petroFieldsFL.clearSelection();
var layerInfos = [
'featureLayer': petroFieldsFL,
'showAttachments': false,
'isEditable': true,
'fieldInfos': [
{'fieldName': 'activeprod', 'isEditable': true, 'tooltip': 'Current Status', 'label': 'Status:'},
{'fieldName': 'field_name', 'isEditable': true, 'tooltip': 'The name of this oil field', 'label': 'Field Name:'},
{'fieldName': 'approxacre', 'isEditable': false, 'label': 'Acreage:'},
{'fieldName': 'avgdepth', 'isEditable': false, 'label': 'Average Depth:'},
{'fieldName': 'cumm_oil', 'isEditable': false, 'label': 'Cummulative Oil:'},
{'fieldName': 'cumm_gas', 'isEditable': false, 'label': 'Cummulative Gas:'}
var attInspector = new AttributeInspector({
layerInfos: layerInfos
}, domConstruct.create("div"));
//add a zoom button next to the delete button
var zoomButton = new Button({ label: "Zoom To", "class": "zoomButton atiButton"},domConstruct.create("div"));
domConstruct.place(zoomButton.domNode, attInspector.deleteBtn.domNode, "after");
zoomButton.on("click", function() {
console.info(updateFeature);
var geom = updateFeature.geometry;
var lod = map.getLevel();
if(geom.type === 'point'){
map.centerAndZoom(geom, lod + 4);
}else{
map.setExtent(geom.getExtent(), true);
//add a save button next to the delete button
var saveButton = new Button({ label: "Save", "class": "saveButton atiButton"},domConstruct.create("div"));
domConstruct.place(saveButton.domNode, attInspector.deleteBtn.domNode, "after");
saveButton.on("click", function() {
updateFeature.getLayer().applyEdits(null, [updateFeature], null);
attInspector.on("attribute-change", function(evt) {
//store the updates to apply when the save button is clicked
updateFeature.attributes[evt.fieldName] = evt.fieldValue;
attInspector.on("next", function(evt) {
updateFeature = evt.feature;
console.log("Next " + updateFeature.attributes.objectid);
attInspector.on("delete", function(evt) {
evt.feature.getLayer().applyEdits(null, null, [evt.feature]);
map.infoWindow.setContent(attInspector.domNode);
map.infoWindow.resize(350, 240);
</script>
</head>
<body class="claro">
<div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width:100%;height:100%;">
<div id="detailPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'">
Click a field to display the attribute inspector with customized fields.
</div>
<div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'" id="mapDiv"></div>
</div>
</body>
</html>
