I'm hoping to filter my results from the first task of a GP service with a subsequent task in a GP service (e.g. using table view or select layer by attributes then deleting rows to filter out unwanted rows). What is the best way to go about this? The first task relies on user defined data. Can I use the 'share as geoprocessing service' option and add results to the service, or do I need to build a single script to run as a tool, then share that tool as a GP service?
Thanks in advance,
Tess
