I am drawing hundreds of graphics (points) on a map and it's too slow in IE -- I get the alert asking if you want to stop the script. So I want to cluster the points and draw one for each set that falls within a certain offset. Are there libs and /or techniques readily available for doing this, or do I have to write it myself? I can see it wouldn't be too difficult to do the clustering but then the graphics need to have an infoWindow, so when clicking on a clustered point I need to display the option to view the attributes for each real data point.
