I want to disable 'snapshot mode' in my SceneView. As described and discussed in this Ideas Post, "Fix 4.2x so that initial requests for large layers are faster" and in these Questions (Post 1, Post 2), the feature can really slow down the loading of large MapService layers. For a MapView (2D) the workaround posted in the links is to configure:
'featurelayer-snapshot-disabled':0
See here.
But now I need to do that in a SceneView because I seem to be having the same issue there.
Here's a simple CodePen of it working for a MapView.
Here's a copied CodePen of same thing failing for a SceneView.
To Test:
Although the effects aren't that significant for this sample data above, you can see that in the sceneView you will still get requests with `returnCountTrue` param which are the snapshot feature requests if you open your browser DevTools to the network pane and watch traffic.
Is there a 3D equivalent of 'featurelayer-snapshot-disabled':0? Help!
