How to dynamically clear the FeatureLayer.popupTemplate
1019
04-12-2021 08:34 AM
ShaningYu
In my App, I defined   myFeatureLayer.popupTemplate;
When I clear the loaded FeatureLayer, the popup still remains on the map.  I have tried the 3 methods below but not effective:
myFeatureLayer.popupTemplate = null;     // Not working
myFeatureLayer.popupTemplate.hide();   // error No such a method
myFeatureLayer.popupTemplate.close();    // error No such a method
How can it be dynamically close the popup?  Thanks.
UndralBatsukh
Hi there,
You should use MapView.popup.close or MapView.popup.visible properties to hide visible popups on the map.
Hope this helps,
-Undral
Tags (1)
UndralBatsukh
Hi there,
Hope this helps,
-Undral
Tags (1)
