How to set a result of a query in a dgrid's memory store in a module
2222
01-15-2016 04:57 PM
PriyaRam
I have a AMD module, which has a public function, to load a feature layer and when the results return I need to populate a grid. I'm having trouble with scope accessing the grid craeted in a private method. I 'm trying to use this.set and watch on the object change , but calling "this.set" gives me a Type error. Please advise, I'm new to dojo framework.
          //Constructor function
          constructor: function (options, srcRefNode) {
                // results holder
                this.set("results", []);
                // watch updates of public properties and update the widget accordingly
                this.watch("results", this._updateMemoryStore);
            // Update geocoder nodes
                _updateMemoryStore: function () {
                   var items =  this.get("results");
                     //idProperty must be set manually if value is something other than 'id'
                    var memStore = new Memory({
                        data: items,
                        idProperty: "ObjectID"
                    console.log(memStore);
          onLoadBndry: function() {
                    queryTask.disableClientCaching = true;
                    queryTask.useAMF = false;
                    queryTask.showBusyCursor = true;
                    queryTask.execute(query,this._showResults);
                _showResults:function(featureSet) {
                    console.log("_showResults");
                     var items = array.map(featureSet.features, function(feature) {
                        return feature.attributes;
                    this.set("results", items); \\TypeError: this.set is not a function
GirishYadav
Hi Priya,
You need to use dojo's lang.hitch on _showResults function call to set the execution scope.
include "dojo/_base/lang" AND
                    queryTask.execute(query, lang.hitch(this, this._showResults));
You might have to do this for call to _updateMemoryStore as well
this.watch("results", lang.hitch(this, this._updateMemoryStore));
-Girish
