Hi ,
I am using Editor Widget for editing a feature service.I need to dynamically change the fieldInofs of the Attribute Inspector inside it based on the feature type clicking.After updating the fieldInofs on the click event,when I click the particular feature type for the first time the new fieldInfo is getting updated but when I click another feature type the attribute inspector is not getting updated with the new fieldInfo.Can anyone help me in this regard.
Below I am furnishing the code snippet:
var fieldInfos1 = [
{ 'fieldName': 'sector', 'label': 'sector', 'isEditable': true }
var fieldInfos2 = [
{ 'fieldName': 'sector', 'label': 'sector', 'isEditable': true },
{ 'fieldName': 'assessment', 'label': 'assessment', 'isEditable': true }
responsePointsFL.on("click", function (evt) {
if (evt.graphic.attributes["activity_t"] == "Aircraft Enemy") {
var sectorField = responsePoints.fields[5];
fieldInfos1[0].field = sectorField;
myEditor.settings.layerInfos[0].fieldInfos = [];
myEditor.settings.layerInfos[0].fieldInfos=fieldInfos1;
else {
var asssesmentField = responsePoints.fields[6];
fieldInfos2[0].field = sectorField;
fieldInfos2[1].field = asssesmentField;
myEditor.settings.layerInfos[0].fieldInfos = fieldInfos2;
Regards,
Kishore Kumar
