I can add a graphic to a layer and then "blink" it using setInterval. But I can not add a graphic to a layer and search for it later via icon button, click and "blink" it. The graphic.visible does not seem to work in this, latter instance. Any suggesti
1844
05-14-2020 06:24 PM
EugeneStaten
New Contributor III
I am working with esri gis api for js 4.15 typescript in an Angular 9 application.
This works:
     var graphic = new graphic({geometry: point, symbol:sign}):
var layer = new GraphicsLayer({id: 'mylayer'});
view.map.add(layer);
layer.when((layerdone)=>{
     setInterval(()=>{
            graphic.visible != graphic.visible;
      }, 1000);
layer.add(graphic);
But this does not:
var glayer = view.map.layers.find((layer)=>{ layer.id === 'mylayer'});
var graphic = glayer.graphics.find():// lets say its found
var count = 0;
var pulser = setInterval(()=>{
if((++count) >= 10){
        clearInterval(pulser);
       pulser = undefined;
      graphic.visible = true;
}, 1000);
Tags (3)
2 Solutions
RobertScheitlin__GISP
Eugene,
   You had a couple of issue in your code. Notice in line 3 I return the boolean value in the find function and again in line 4 I return the boolean value. Then in line 6 I changed the way you were setting the graphics visibility.
        // click event for the button
        flashButton.addEventListener("click", function() {
          var glayer = view.map.layers.find((layer)=>{return layer.id === 'mylayer'});
          var graphic = glayer.graphics.find((gra)=>{return gra.geometry.type === 'polygon'});
          setInterval(()=>{
            graphic.visible = !graphic.visible;
          }, 1000);
EugeneStaten
New Contributor III
Thanks Robert,
This works!!!   Thanks!!!
Change from != to = ! did the trick.
Cheers to community brain trust.
EugeneStaten
New Contributor III
Im using esri api for js 4.15.
Eugene,
          setInterval(()=>{
          }, 1000);
EugeneStaten
New Contributor III
Thanks Robert,
