You need to use the 'On Style Events' syntax. To find the appropriate syntax navigate to the API reference for the Identity Manager then in the Events section click the 'On Style Events' link. Then you'll see the new event names - for example you'll need to use dialog-cancel instead of OnDialogCancel.
