Original User: hbosticHello, I'm defining an infotemplate as newMemberTemplate = new esri.InfoTemplate();
newMemberTemplate.setTitle("<b>New User Information</b>");
newMemberTemplate.setContent(getTextContent);
applying it like var deferred = censustract.selectFeatures(query,esri.layers.FeatureLayer.SELECTION_NEW);
censustract.setInfoTemplate(newMemberTemplate);
map.infoWindow.setFeatures([deferred]);
map.infoWindow.show(pointMeters);
where getTextContent returns:var newEntry = new com.urs.greenteam.widgets.testWidget({id:"entryScreen"});
return newEntry.domNode;
My issues are:1. the infowindow title is blank2. the infowindow does not seem to respect data-dojo-* syntax so I have to use dojoType = and explicitly set my attributes3. for dojo.form.TextBox the placeHolder text is not honored in IEHTML for com.urs.greenteam.widgets.testWidget:[HTML]<input id="search" name="search" value="" dojoType="dijit.form.ValidationTextBox" data-dojo-props="trim:true, propercase:true, style:'width: 20em;', placeHolder:'Parcel ID, Address, Lat & Long, Zip Code'"/> <input type="text" name="employeeName" size="30" placeHolder = "Enter Your Name" required="true" dojoType="dijit.form.ValidationTextBox" trim="true" id="employeeName" propercase="true"> <input type="text" name="firstname" value="" data-dojo-type="dijit.form.TextBox" data-dojo-props="trim:true, propercase:true, placeHolder:Parcel ID, Address, Lat & Long, Zip Code" id="firstname"><br> <div dojoType="dijit.layout.ContentPane"> <input id="searchAddress" data-dojo-attach-point="_searchAddress" name="searchAddress" value="" dojoType="dijit.form.TextBox" trim="true" propercase="true" selectOnClick="true" size="30" placeHolder="Address" /> </div>[/HTML]Any help would be gladly appreciated
