is it possible for the Sketch UI widget, that it only shows the sketch point button?
1055
03-08-2019 05:18 AM
WwLl
New Contributor II
Hey,
i want only the Point Button, can i somehow turn off the other function?
thanks!
RobertScheitlin__GISP
Just add this css rule to your code:
  .esri-sketch__button.esri-icon-polyline,
    .esri-sketch__button.esri-icon-polygon,
    .esri-sketch__button.esri-icon-checkbox-unchecked,
    .esri-sketch__button.esri-icon-radio-unchecked {
      display:none;
WwLl
New Contributor II
Thanks, it worked
JonathanUihlein
We will be adding a property to control the display of specific tools in an upcoming release (4.12). In the meantime, you can use Robert's solution.
GregoryBologna
Occasional Contributor II
add what you want
          var sketch = new Sketch({
            layer: somelayer
            view: view,
            availableCreateTools: ["polyline""polygon""rectangle""circle"]
