Is not a constructor - seatgeeksearch tutorial
2868
10-02-2013 08:52 PM
thomasenns1
I'm upgrading my code to amd and educating myself with the Seatgeeksearch tutorial.  I've done this, now, on a couple different machines and I get an error - "Seatgeeksearch is not a constructor".   Any help or direction would be greatly appreciated.  I seems at though seatgeeksearch.js seems to load okay.
derekswingley1
Please post your code that shows the problem. The example using the code from that tutorial works without issue:  http://servicesbeta.esri.com/demos/using-classes-with-javascript/seatgeek-search/
WillHughes1
Occasional Contributor II
define(
    ["dojo/_base/declare", "dojo/_base/lang", "esri/request"],
    function (declare, lang, esriRequest) {
        declare(null,
                distance: null,
  lastSearchResult: null,
  perPage: null,
  queryParams: null,
  seatGeekUrl: null,
  constructor: function (options) {
    // specify class defaults
    this.distance = options.distance || "20mi"; // default seat geek range is 30mi
    this.perPage = options.perPageage || 50; // default to 50 results per page
    this.seatGeekUrl = "http://api.seatgeek.com/2/events";
    // returnEvents is called by an external function, esri.request
    // hitch() is used to provide the proper context so that returnEvents
    // will have access to the instance of this class
    this.returnEvents = lang.hitch(this, this.returnEvents);
  searchByLoc: function (geopoint) {
    var eventsResponse;
    this.queryParams = {
      "lat": geopoint.y,
      "lon": geopoint.x,
      "page": 1,
      "per_page": this.perPage,
      "range": this.distance
    // seat geek endpoints:
    // petco park search using lat, lon:
    // http://api.seatgeek.com/2/events?lat=32.7078&lon=-117.157&range=20mi&callback=c
    // lat, lon for petco park:  32.7078, -117.157
    eventsResponse = esriRequest({
      "url": this.seatGeekUrl,
      "callbackParamName": "callback",
      "content": this.queryParams
    return eventsResponse.then(this.returnEvents, this.err);
  getMore: function() {
    var eventsResponse;
    // increment the page number
    this.queryParams.page++;
    eventsResponse = esri.request({
  returnEvents: function(response) {
    // check number of results
    if ( response.meta.total == 0) {
      // console.log("Seat Geek returned zero events: ", response);
      return null;
    // save search result
    this.lastSearchResult = response;
    // console.log("set last search result: ", response, this);
    return response;
  err: function(err) {
    console.log("Failed to get results from Seat Geek due to an error: ", err);
WillHughes1
I was able to get this to work by adding "return" before declare on line 4.
define(
      return declare(null,
Without return I was seeing the same "not a constructor" error mentioned in the original post.
It would be great if the Tutorial files were made available in the Samples or on GitHub. Thanks.
