Is there a print view for arcGIS API for javaScript????
2358
10-07-2015 07:54 AM
JamesFitzgerald
Occasional Contributor II
Hello all,
I would like to add a print view button so staff can see what they will be printing. I have looked in ArcGIS API for javaScript but only found information on how to print. Seems to be a way to also print preview or view print extents.
Thanks
RickeyFight
MVP Regular Contributor
James,
Look at this sample
http://developers.arcgis.com/javascript/samples/widget_print_webmap/
If you hit print, it will create a pdf. The user can view the pdf and then if it is what is desired the user can then print it.
JamesFitzgerald
Thanks!
SteveCole
Although this was built for use with Web AppBuilder projects, this Print Plus widget is pretty nifty.
Live demo.
JamesFitzgerald
Thanks!
