Issue on Loading Saver Side Zip File to ESRI Request
1237
08-06-2017 09:41 AM
BehrouzHosseini
ArcGIS JavaScript API is using This Demo to upload and pass a Zipped shapefile to esriRequest using "esri/request" module.
Now my question is is there any way that we load and pass a zipped shaefile from Server and not from client side like accessing the file by Ajax?
at current demo , thr form option is filling by `uploadForm` elemt by user submit at
    form: dom.byId('uploadForm'),
request({
    url: portalUrl + '/sharing/rest/content/features/generate',
    content: myContent,
    handleAs: 'json',
    load: lang.hitch(this, function (response) {
    if (response.error) {
      errorHandler(response.error);
      return;
    var layerName = response.featureCollection.layers[0].layerDefinition.name;
      addShapefileToMap(response.featureCollection);
    error: lang.hitch(this, errorHandler)
Now, I need to pass a file directly to the options instead of using HTML File Dialog and Input. Something like:
//Get the zipped file from Ajax Call and pass it to a data variable
var data = "www.domain.com/GIS/App.ZIP";
// assign form with data
 request({
 form: data,
JohnGrayson
Bengi, below is the relevant code, and here's a modified version of the 'Add Shapefile' sample: Add Shapefile
// STEP #1a - GET ZIPPED SHAPEFLE FROM EXTERNAL SERVER //
var urlToExternalZippedShapefile = "http://apps.sfgov.org/datafiles/view.php?file=sfgis";
var zippedShapefileName = "sflnds_current";
request({
  url: lang.replace("{0}/{1}.zip", [urlToExternalZippedShapefile, zippedShapefileName]),
  handleAs: "blob",
  load: function (zipResponse) {
    // STEP #1b - CREATE FORM USING RETURNED ZIPPED SHAPEFILE AS BLOB //
    var formNode = domConstruct.create("form", {
      "method": "post",
      "enctype": "multipart/form-data"
    var formData = new FormData(formNode);
    formData.append("file", zipResponse, zippedShapefileName + ".zip");
    // THIS PART STAYS ALMOST SAME AS BEFORE //
    var params = {
      'name': zippedShapefileName,
      'targetSR': map.spatialReference,
      'maxRecordCount': 1000,
      'enforceInputFileSizeLimit': true,
      'enforceOutputJsonSizeLimit': true
    var extent = scaleUtils.getExtentForScale(map, 40000);
    var resolution = extent.getWidth() / map.width;
    params.generalize = false;
    params.maxAllowableOffset = resolution;
    params.reducePrecision = true;
    params.numberOfDigitsAfterDecimal = 0;
    var myContent = {
      'filetype': 'shapefile',
      'publishParameters': JSON.stringify(params),
      'f': 'json'
    // STEP #2 - CALL 'GENERATE' TO CONVERT SHAPEFILE TO FEATURECOLLECTION BUT USING BLOB NOW //
    request({
      content: myContent,
      form: formData,  // NOTICE HOW WE USE THE FORMDATA OBJECT THAT HAS THE EMBEDDED ZIPPED SHAPEFILE AS A BLOB //
      handleAs: 'json',
        if(response.error) {
          return;
        dom.byId('upload-status').innerHTML = '<b>Loaded: </b>' + layerName;
JohnGrayson
Bengi, is this the same question as How to Pass File Directly to esriRequest Instead of Using Form Upload?  This task will probably involve a two step process; first get the file from the server and then call the 'generate' endpoint. The important thing here is to understand the call you're trying to make: Generate: ArcGIS REST API.  The call to 'generate' doesn't have a parameter for URLs and since you're dealing with a zipped shapefile you'll have to use the 'file' parameter which then means you need to send the actual zipped shapefile as a file.  Since the zipped shapefile is on a different server you'll first need to get the file to the client machine before sending it to the 'generate' call.  Do you have a JSBin or JSFiddle that shows what you're trying to do?
JohnGrayson
request({
  handleAs: "blob",
      "method": "post",
    var params = {
    var myContent = {
      'f': 'json'
    request({
      content: myContent,
      handleAs: 'json',
          return;
BehrouzHosseini
Great, Thanks a lots John,
but I am getting an error on my side! I download the `sflnds_current.zip` file from your sample server and load it to localhost directory at
http://localhost/Portal/
I also copy entire code of the demo page you gave me and updated the urlToExternalZippedShapefile as below
var urlToExternalZippedShapefile = "http://localhost/Portal/";
var zippedShapefileName = "sflnds_current";‍‍‍‍
but when I run the code I am getting this error message:
Cannot read property 'expand' of undefined
Can you please let me know what I am doing wrong here? Again Thanks
JohnGrayson
The error seems to happen after you've gotten past the download part so it's hard to tell what is going on.  Try debugging the app an add a breakpoint at the line that makes the 'getExtentForScale()' call; that might help you figure it out.
