Dru,
You are getting a sub-optimal route because of how the routing algorithm works for this particular case. Let me elaborate a bit more on this. By default, the routing algorithm is using hierarchy which is a way to say that get on higher level streets such as freeways as quickly as you can from your starting location and then stay on higher level streets for as long as you can until you are close to your destination.
The opposite approach to this is to use all the available streets and find the shortest route. This is called exact route. Finding an exact route is computationally intensive as the "search" space can be very large. For example, imagine finding a route between LA and New York, using the exact approach. Such a request has the possibility of searching through most of the street network and probably run out of memory or time out.
So for any "long" routes, the routing service in ArcGIS Online (the one used by Directions widget by default) only finds hierarchical routes. The service does support finding exact routes but limits the extent of input stops to be up to 50 miles. That's to say you can do exact routes only for short routes.
The routing service API also supports what we call as overrides. These are additional settings that can be passed to the service to override certain default behavior of the algorithms. One such override setting is called TopHierarchyLevel. The default value for this setting is 1. Setting this to a higher value essentially allows the service to consider more streets before it hops on to a higher level street. Using your stops as input and a value of 4 for this property, gets you a route very similar to the one you are getting on google maps.
Below are the request parameters for the same route but with TopHierarchyLevel set to 4. With this the total travel time is now 85 minutes (as compared to 95.4 minutes).
The directions widget does not expose setting the overrides. However if you can use the RouteTask from ArcGIS JavaScript API, you can set the overrides parameter on RouteParameters to get this route.
In general the hierarchical routing algorithms works fine for most cases. But occasionally, you run into such cases for which you need to override some settings to get the desired route.
f=json&returnDirections=true&returnRoutes=false&returnZ=true&returnStops=true&returnBarriers=false&returnPolygonBarriers=false&returnPolylineBarriers=false&outSR=102100&outputLines=esriNAOutputLineTrueShape&findBestSequence=false&preserveFirstStop=true&preserveLastStop=true&useTimeWindows=true&startTime=1519240930076&startTimeIsUTC=true&timeWindowsAreUTC=true&accumulateAttributeNames=Miles%2CKilometers%2CMinutes%2CTravelTime&ignoreInvalidLocations=true&restrictUTurns=esriNFSBAtDeadEndsOnly&directionsLanguage=en&outputGeometryPrecision=0&outputGeometryPrecisionUnits=esriMeters&directionsLengthUnits=esriNAUMiles&travelMode=%7B%22attributeParameterValues%22%3A%5B%7B%22parameterName%22%3A%22Restriction+Usage%22%2C%22attributeName%22%3A%22Avoid+Unpaved+Roads%22%2C%22value%22%3A%22AVOID_HIGH%22%7D%2C%7B%22parameterName%22%3A%22Restriction+Usage%22%2C%22attributeName%22%3A%22Avoid+Private+Roads%22%2C%22value%22%3A%22AVOID_MEDIUM%22%7D%2C%7B%22parameterName%22%3A%22Restriction+Usage%22%2C%22attributeName%22%3A%22Driving+an+Automobile%22%2C%22value%22%3A%22PROHIBITED%22%7D%2C%7B%22parameterName%22%3A%22Restriction+Usage%22%2C%22attributeName%22%3A%22Through+Traffic+Prohibited%22%2C%22value%22%3A%22AVOID_HIGH%22%7D%2C%7B%22parameterName%22%3A%22Vehicle+Maximum+Speed+(km%2Fh)%22%2C%22attributeName%22%3A%22TravelTime%22%2C%22value%22%3A0%7D%2C%7B%22parameterName%22%3A%22Restriction+Usage%22%2C%22attributeName%22%3A%22Roads+Under+Construction+Prohibited%22%2C%22value%22%3A%22PROHIBITED%22%7D%2C%7B%22parameterName%22%3A%22Restriction+Usage%22%2C%22attributeName%22%3A%22Avoid+Gates%22%2C%22value%22%3A%22AVOID_MEDIUM%22%7D%2C%7B%22parameterName%22%3A%22Restriction+Usage%22%2C%22attributeName%22%3A%22Avoid+Express+Lanes%22%2C%22value%22%3A%22PROHIBITED%22%7D%2C%7B%22parameterName%22%3A%22Restriction+Usage%22%2C%22attributeName%22%3A%22Avoid+Carpool+Roads%22%2C%22value%22%3A%22PROHIBITED%22%7D%5D%2C%22description%22%3A%22Models+the+movement+of+cars+and+other+similar+small+automobiles%2C+such+as+pickup+trucks%2C+and+finds+solutions+that+optimize+travel+time.+Travel+obeys+one-way+roads%2C+avoids+illegal+turns%2C+and+follows+other+rules+that+are+specific+to+cars.+When+you+specify+a+start+time%2C+dynamic+travel+speeds+based+on+traffic+are+used+where+it+is+available.%22%2C%22impedanceAttributeName%22%3A%22TravelTime%22%2C%22simplificationToleranceUnits%22%3A%22esriMeters%22%2C%22uturnAtJunctions%22%3A%22esriNFSBAtDeadEndsAndIntersections%22%2C%22restrictionAttributeNames%22%3A%5B%22Avoid+Unpaved+Roads%22%2C%22Avoid+Private+Roads%22%2C%22Driving+an+Automobile%22%2C%22Through+Traffic+Prohibited%22%2C%22Roads+Under+Construction+Prohibited%22%2C%22Avoid+Gates%22%2C%22Avoid+Express+Lanes%22%2C%22Avoid+Carpool+Roads%22%5D%2C%22useHierarchy%22%3Atrue%2C%22simplificationTolerance%22%3A10%2C%22timeAttributeName%22%3A%22TravelTime%22%2C%22distanceAttributeName%22%3A%22Kilometers%22%2C%22type%22%3A%22AUTOMOBILE%22%2C%22id%22%3A%22FEgifRtFndKNcJMJ%22%2C%22name%22%3A%22Driving+Time%22%7D&stops=%7B%22type%22%3A%22features%22%2C%22features%22%3A%5B%7B%22geometry%22%3A%7B%22x%22%3A-9061941.545%2C%22y%22%3A4778115.294699997%2C%22spatialReference%22%3A%7B%22wkid%22%3A102100%2C%22latestWkid%22%3A3857%7D%7D%2C%22attributes%22%3A%7B%22CurbApproach%22%3Anull%2C%22TimeWindowStart%22%3Anull%2C%22TimeWindowEnd%22%3Anull%2C%22Attr_Minutes%22%3A0%2C%22Attr_TravelTime%22%3A0%2C%22Attr_Miles%22%3A0%2C%22Attr_Kilometers%22%3A0%2C%22Attr_TimeAt1KPH%22%3A0%2C%22Attr_WalkTime%22%3A0%2C%22Attr_TruckMinutes%22%3A0%2C%22Attr_TruckTravelTime%22%3A0%2C%22Name%22%3A%221400+Pike+St%2C+Marietta%2C+OH%2C+45750%2C+USA_1008%22%7D%7D%2C%7B%22geometry%22%3A%7B%22x%22%3A-9149838.8682%2C%22y%22%3A4827500.293799996%2C%22spatialReference%22%3A%7B%22wkid%22%3A102100%2C%22latestWkid%22%3A3857%7D%7D%2C%22attributes%22%3A%7B%22CurbApproach%22%3Anull%2C%22TimeWindowStart%22%3Anull%2C%22TimeWindowEnd%22%3Anull%2C%22Attr_Minutes%22%3A0%2C%22Attr_TravelTime%22%3A0%2C%22Attr_Miles%22%3A0%2C%22Attr_Kilometers%22%3A0%2C%22Attr_TimeAt1KPH%22%3A0%2C%22Attr_WalkTime%22%3A0%2C%22Attr_TruckMinutes%22%3A0%2C%22Attr_TruckTravelTime%22%3A0%2C%22Name%22%3A%223210+State+Route+345+NE%2C+New+Lexington%2C+Ohio%2C+43764%2C+USA_1009%22%7D%7D%5D%2C%22doNotLocateOnRestrictedElements%22%3Atrue%7D&directionsOutputType=esriDOTComplete&overrides=%7B%22TopHierarchyLevel%22+%3A+4%7D
