I finally took the plunge a couple weeks ago and decided I really needed to break up my code. I think 'break it into modules' sounds good, but it doesn't really explain how to do it.
First of all, you don't have to have break it up into tiny pieces. Just breaking the major functionality of my code into separate files has helped me keep track.
So far I am mostly just using my code for functions.
First I create a new folder in your project. This one is called extras, although it could be anything as long as you keep track of the name.
Then I add this folder to my dojoConfig as an additional package. I've also been using bootstrap-map, so there's an entry for it as well.
<script type="text/javascript">
window.dojoConfig = {
async: true,
parseOnLoad:false,
packages: [
location: window.location.pathname.substring(0, window.location.pathname.lastIndexOf('/')) + "/extras"
</script>
Then in my extras folder, I create my .js files
You only need to define the components you're using for this js file as opposed to 'spaghetti' mode where you have a huge list of all modules you need in your code. This particular.js file does one thing, create your map.
There are a few syntax difference between having your functions in index.html and their own .js file.
1) Instead of 'require' now that it's in your .js file, you'll using 'define' instead.
After the function, you'll see
return {
createMap: function (mapDiv,pathName)
2) This is another syntax difference, the word 'function' doesn't come first, the name of the function does, followed by a colon, then the word 'function' and whatever arguments you will be passing.
define ([
"dojo/dom-construct",
"dojo/on",
"dojo/dom",
"esri/dijit/Popup",
"esri/SpatialReference",
"esri/geometry/Extent",
"esri/layers/FeatureLayer",
"esri/layers/LabelLayer",
"esri/symbols/SimpleMarkerSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/symbols/TextSymbol",
"esri/Color",
"esri/renderers/SimpleRenderer",
'bootstrap-map-js/js/bootstrapmap'
], function (
domConstruct,on,dom,Popup,SpatialReference, Extent,
FeatureLayer, LabelLayer,
SimpleMarkerSymbol, SimpleLineSymbol,TextSymbol,
Color,SimpleRenderer,BootstrapMap) {
return {
createMap: function(mapDiv, pathName){
config = {
countyLayerUrl: pathName + '/arcgis/rest/services/BaseMap/county_simple/MapServer/0'
app.spatialReference = new SpatialReference({
wkid: 102100
var startExtent = new Extent(-10583000, 4287025, -9979000, 4980462, app.spatialReference);
app.currentExtent = startExtent;
var popup = new Popup({
markerSymbol: new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 22, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 255, 0]), 2), new Color([255, 255, 0, 0.5]))
}, domConstruct.create("div"));
var highlightMarkerSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 22, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 255, 0]), 2), new Color([255, 255, 0, 0.5]));
var simpleMarkerSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 8, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0]), 2), new Color([255, 0, 0, 0.5]));
markerSymbol: highlightMarkerSymbol
app.map = BootstrapMap.create(mapDiv, {
basemap: "gray",
extent: startExtent,
sliderPosition: 'upper-left',
autoResize: true,
scrollWheelZoom: true,
fitExtent: true,
infoWindow: popup
var countyLayer = new FeatureLayer(config.countyLayerUrl, {
mode: FeatureLayer.MODE_ONDEMAND,
outFields: ["COUNTYNAME"]
//label the counties feature layer
var countyColor = new Color("#666");
var countyText = new TextSymbol();
countyText.setColor(countyColor);
countyText.font.setSize("7pt");
var countyLabelRenderer = new SimpleRenderer(countyText);
countyLabelLayer = new LabelLayer({
maxScale: 1155582
countyLabelLayer.addFeatureLayer(countyLayer, countyLabelRenderer, '{COUNTYNAME}');
app.map.addLayers([ countyLayer, countyLabelLayer]);
In my index.html, I've been creating a variable window.app = {}. This is a handy container for defining objects that continue to be available to other modules. Since I know I will need map, spatialReference etc in other parts of my code, I have defined them in myMap.js as app.map and app.spatialReference, where they'll reside in the app variable to be used again.
Lastly, you need to require myMap, just like you do any others. Since the createMap function has two arguments, you'll need to pass the pathName and the mapDiv where you want your map to be displayed:
<!DOCTYPE html>
<html lang="en">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<title>Map - Modules</title>
<link rel="stylesheet" href="https://community.esri.com//netdna.bootstrapcdn.com/bootstrap/3.1.1/css/bootstrap.min.css">
<link rel="stylesheet" type="text/css" href="https://community.esri.com//js.arcgis.com/3.13/esri/css/esri.css">
<link rel="stylesheet" type="text/css" href="https://community.esri.com//esri.github.io/bootstrap-map-js/dist/css/bootstrapmap.min.css">
<link rel="stylesheet" href="https://community.esri.com//xsokev.github.io/Dojo-Bootstrap/css/styles.css">
<link rel="stylesheet" href="css/app.css">
</head>
<body>
async: true,
parseOnLoad:false,
packages: [
</script>
<script type="text/javascript" src="//js.arcgis.com/3.13compact"></script>
require(["dojo/parser","dojo/on","dojo/dom","extras/myMap","dojo/domReady!"
function(parser,on,dom,myMap
parser.parse();
var pathName = "https://yourservername.gov";
window.app = {}; //the app variable will be persistent throughout your code
myMap.createMap(dom.byId('mapDiv'),pathName);
</script>
<div id="mapDiv">
</div>
</body>
</html>
