JS Class Print: really ArcGIS Server 10.1 required, 10.3 not working?
3024
06-18-2015 02:17 AM
TobiasBrühlmeier1
New Contributor III
Hi there
Just to be absolutely sure:
In Esri's documentation ArcGIS API for JavaScript, for the Class "Print" , it's said:
Note: The Print widget requires an ArcGIS Server 10.1 Export Web Map Task.
(See Print | API Reference | ArcGIS API for JavaScript)
I guess that newer (or maybe less ancient) versions of ArcGIS for Server (like version 10.3) are supported as well, aren't they?
Regards, Tobias
YousefQuran
Yes! for sure newer versions of ArcGIS for Server are supported as well.
Regards,
Yusuf
YousefQuran
Regards,
Yusuf
TobiasBrühlmeier1
New Contributor III
Thanks, it was just to be sure...
