LabelClass with where clause
2397
02-23-2016 04:36 AM
AnasKanaan
hey!
i am wondering if somebody has done some sort of test regarding labelclass with where clause
i have already used the sandbox mentioned in the documentation with the following where clause code as mentioned in the documentation as well
labelClass.where = "areaname='Redlands'"
ArcGIS API for JavaScript Sandbox
i changed areaname to STATE_NAME and replaced Redlands to Texas for example and the filtering does not work at all
i just get no labels att all
i have played a little with the syntax and get it working with the following code
labelClass.where = "'STATE_NAME' = Utah";
i have also another question regarding the use of LIKE statement instead of equal
is there somebody who has an idea who can we do this for example
labelClass.where = "'STATE_NAME' like '%U'";
DavidChambers1
New Contributor III
Hi Anas Kanaan​ it looks like there is a current issue with the where clause and the labelClass and I have experienced the same behavior as well. From my experience, if you need to use custom logic with labels in JavaScript it's easier to:
1. Publish Annotation from ArcMap
2. Use a TextSymbol instead of a LabelClass.  Go the service and get the labels you need, then consume them with a TextSymbol.  This gives you more fine-grained control.
