<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Identify with Popup</title> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css"> <style> html, body, #map { height:100%; width:100%; margin:0; padding:0; } #rightPane { width: 20%; } #legendPane { border: solid #97DCF2 1px; } </style> <script src="http://js.arcgis.com/3.9/"></script> <script> var map; require([ "esri/map", "esri/InfoTemplate", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol", "esri/tasks/IdentifyTask", "esri/tasks/IdentifyParameters", "esri/dijit/Popup", "dojo/_base/array", "esri/Color", "dojo/dom-construct", "dojo/parser", "esri/arcgis/utils", "esri/dijit/Legend", "dojo/dom", "dijit/form/CheckBox", "dijit/layout/AccordionContainer", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!" ], function ( Map, InfoTemplate, ArcGISDynamicMapServiceLayer, SimpleFillSymbol, SimpleLineSymbol, IdentifyTask, IdentifyParameters, Popup, arrayUtils, Color, domConstruct, parser, utils, Legend, dom, CheckBox ) { parser.parse(); var identifyTask, identifyParams; var legendLayers = []; var popup = new Popup({ fillSymbol: new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.25])) }, domConstruct.create("div")); map = new Map("map", { basemap: "satellite", center: [-83.275, 42.573], zoom: 18, infoWindow: popup }); map.on("load", mapReady); var parcelsURL = "http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/BloomfieldHillsMichigan/Parcels/MapServer"; map.addLayer(new ArcGISDynamicMapServiceLayer(parcelsURL, { "id": "Parcels" })); legendLayers.push({ layer: parcelsURL, title: "Place" }); function mapReady () { map.on("click", executeIdentifyTask); //create identify tasks and setup parameters identifyTask = new IdentifyTask(parcelsURL); identifyParams = new IdentifyParameters(); identifyParams.tolerance = 3; identifyParams.returnGeometry = true; identifyParams.layerIds = [0, 2]; identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_ALL; identifyParams.width = map.width; identifyParams.height = map.height; } function executeIdentifyTask (event) { identifyParams.geometry = event.mapPoint; identifyParams.mapExtent = map.extent; var deferred = identifyTask .execute(identifyParams) .addCallback(function (response) { // response is an array of identify result objects // Let's return an array of features. return arrayUtils.map(response, function (result) { var feature = result.feature; var layerName = result.layerName; feature.attributes.layerName = layerName; if (layerName === 'Tax Parcels') { var taxParcelTemplate = new InfoTemplate("", "${Postal Address} <br/> Owner of record: ${First Owner Name}"); feature.setInfoTemplate(taxParcelTemplate); } else if (layerName === 'Building Footprints') { console.log(feature.attributes.PARCELID); var buildingFootprintTemplate = new InfoTemplate("", "Parcel ID: ${PARCELID}"); feature.setInfoTemplate(buildingFootprintTemplate); } return feature; }); }); // InfoWindow expects an array of features from each deferred // object that you pass. If the response from the task execution // above is not an array of features, then you need to add a callback // like the one above to post-process the response and return an // array of features. map.infoWindow.setFeatures([deferred]); map.infoWindow.show(event.mapPoint); } map.on('layers-add-result', function () { var legend = new Legend({ map: map, layerInfos: legendLayers }, "legendDiv"); legend.startup(); }); map.on('layers-add-result', function () { //add check boxes arrayUtils.forEach(legendLayers, function (layer) { var layerName = layer.title; var checkBox = new CheckBox({ name: "checkBox" + layer.layer.id, value: layer.layer.id, checked: layer.layer.visible }); checkBox.on("change", function () { var targetLayer = map.getLayer(this.value); targetLayer.setVisibility(!targetLayer.visible); this.checked = targetLayer.visible; }); //add the check box and label to the toc domConstruct.place(checkBox.domNode, dom.byId("toggle"), "after"); var checkLabel = domConstruct.create('label', { 'for': checkBox.name, innerHTML: layerName }, checkBox.domNode, "after"); domConstruct.place("<br />", checkLabel, "after"); }); }); }); </script> </head> <body class="claro"> <!--[if IE 7]> <style> html, body { margin: 0; } </style> <![endif]--> <div id="content" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:true" style="width: 100%; height: 100%; margin: 0;"> <div id="rightPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'"> <div data-dojo-type="dijit/layout/AccordionContainer"> <div data-dojo-type="dijit/layout/ContentPane" id="legendPane" data-dojo-props="title:'Legend', selected:true"> <div id="legendDiv"></div> </div> <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="title:'Natural Disasters'"> <span style="padding:10px 0;">Click to toggle the visibility </span> <div id="toggle" style="padding: 2px 2px;"></div> </div> </div> </div> <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'" style="overflow:hidden;"> </div> </div> </body> </html>
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Identify with Popup</title> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css"> <style> html, body, #map { height:100%; width:100%; margin:0; padding:0; } #rightPane { width: 20%; } #legendPane { border: solid #97DCF2 1px; } </style> <script src="http://js.arcgis.com/3.9/"></script> <script> var map; require([ "esri/map", "esri/InfoTemplate", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol", "esri/tasks/IdentifyTask", "esri/tasks/IdentifyParameters", "esri/dijit/Popup", "dojo/_base/array", "esri/Color", "dojo/dom-construct", "dojo/parser", "esri/arcgis/utils", "esri/dijit/Legend", "dojo/dom", "dijit/form/CheckBox", "dijit/layout/AccordionContainer", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!" ], function ( Map, InfoTemplate, ArcGISDynamicMapServiceLayer, SimpleFillSymbol, SimpleLineSymbol, IdentifyTask, IdentifyParameters, Popup, arrayUtils, Color, domConstruct, parser, utils, Legend, dom, CheckBox ) { parser.parse(); var identifyTask, identifyParams; var legendLayers = []; var popup = new Popup({ fillSymbol: new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.25])) }, domConstruct.create("div")); map = new Map("map", { basemap: "satellite", center: [-83.275, 42.573], zoom: 18, infoWindow: popup }); map.on("load", mapReady); var legendLayers = []; var parcelsURL = "http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/BloomfieldHillsMichigan/Parcels/MapServer"; var parcelLayer = new ArcGISDynamicMapServiceLayer(parcelsURL, { id: 'parcels' }); legendLayers.push({ layer: parcelLayer, title: 'Parcels' }); map.on('layers-add-result', function () { var legend = new Legend({ map: map, layerInfos: legendLayers }, "legendDiv"); legend.startup(); }); map.addLayers([parcelLayer ]); map.on('layers-add-result', function () { //add check boxes arrayUtils.forEach(legendLayers, function (layer) { var layerName = layer.title; var checkBox = new CheckBox({ name: "checkBox" + layer.layer.id, value: layer.layer.id, checked: layer.layer.visible }); checkBox.on("change", function () { var targetLayer = map.getLayer(this.value); targetLayer.setVisibility(!targetLayer.visible); this.checked = targetLayer.visible; }); //add the check box and label to the toc domConstruct.place(checkBox.domNode, dom.byId("toggle"), "after"); var checkLabel = domConstruct.create('label', { 'for': checkBox.name, innerHTML: layerName }, checkBox.domNode, "after"); domConstruct.place("<br />", checkLabel, "after"); }); }); function mapReady () { map.on("click", executeIdentifyTask); //create identify tasks and setup parameters identifyTask = new IdentifyTask(parcelsURL); identifyParams = new IdentifyParameters(); identifyParams.tolerance = 3; identifyParams.returnGeometry = true; identifyParams.layerIds = [0, 2]; identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_ALL; identifyParams.width = map.width; identifyParams.height = map.height; } function executeIdentifyTask (event) { identifyParams.geometry = event.mapPoint; identifyParams.mapExtent = map.extent; var deferred = identifyTask .execute(identifyParams) .addCallback(function (response) { // response is an array of identify result objects // Let's return an array of features. return arrayUtils.map(response, function (result) { var feature = result.feature; var layerName = result.layerName; feature.attributes.layerName = layerName; if (layerName === 'Tax Parcels') { var taxParcelTemplate = new InfoTemplate("", "${Postal Address} <br/> Owner of record: ${First Owner Name}"); feature.setInfoTemplate(taxParcelTemplate); } else if (layerName === 'Building Footprints') { console.log(feature.attributes.PARCELID); var buildingFootprintTemplate = new InfoTemplate("", "Parcel ID: ${PARCELID}"); feature.setInfoTemplate(buildingFootprintTemplate); } return feature; }); }); // InfoWindow expects an array of features from each deferred // object that you pass. If the response from the task execution // above is not an array of features, then you need to add a callback // like the one above to post-process the response and return an // array of features. map.infoWindow.setFeatures([deferred]); map.infoWindow.show(event.mapPoint); } }); </script> </head> <body class="claro"> <div id="content" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:true" style="width: 100%; height: 100%; margin: 0;"> <div id="rightPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'"> <div data-dojo-type="dijit/layout/AccordionContainer"> <div data-dojo-type="dijit/layout/ContentPane" id="legendPane" data-dojo-props="title:'Legend', selected:true"> <div id="legendDiv"></div> </div> <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="title:'Natural Disasters'"> <span style="padding:10px 0;">Click to toggle the visibility </span> <div id="toggle" style="padding: 2px 2px;"></div> </div> </div> </div> <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'" style="overflow:hidden;"></div> </div> </body> </html>
map.on("load", mapReady); function mapReady () { map.on("click", executeIdentifyTask); //create identify tasks and setup parameters identifyTask = new IdentifyTask(parcelsURL); identifyParams = new IdentifyParameters(); identifyParams.tolerance = 3; identifyParams.returnGeometry = true; identifyParams.layerIds = [0, 2]; identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_ALL; identifyParams.width = map.width; identifyParams.height = map.height; } function executeIdentifyTask (event) { identifyParams.geometry = event.mapPoint; identifyParams.mapExtent = map.extent; var deferred = identifyTask .execute(identifyParams) .addCallback(function (response) { // response is an array of identify result objects // Let's return an array of features. return arrayUtils.map(response, function (result) { var feature = result.feature; var layerName = result.layerName; feature.attributes.layerName = layerName; if (layerName === 'Tax Parcels') { var taxParcelTemplate = new InfoTemplate("", "${Postal Address} <br/> Owner of record: ${First Owner Name}"); feature.setInfoTemplate(taxParcelTemplate); } else if (layerName === 'Building Footprints') { console.log(feature.attributes.PARCELID); var buildingFootprintTemplate = new InfoTemplate("", "Parcel ID: ${PARCELID}"); feature.setInfoTemplate(buildingFootprintTemplate); } return feature; }); }); // InfoWindow expects an array of features from each deferred // object that you pass. If the response from the task execution // above is not an array of features, then you need to add a callback // like the one above to post-process the response and return an // array of features. map.infoWindow.setFeatures([deferred]); map.infoWindow.show(event.mapPoint); }
