webmap.itemData = { "operationalLayers": [ //Developable Land (display tiled service) { "url": "http://gis.tpcmaps.org/ArcGIS/rest/services/LandUse/Developable_Land/MapServer", "visibility": false, "opacity": 1, //"visibleLayers": [], //"minScale": 100000, //"maxScale": 0, "title": "Developable Land", "id": "devland", "description": null }, //Community-Based Planning Area (display dynamic map service) { "url": "http://gis.tpcmaps.org/ArcGIS/rest/services/Websites/tpcCPA/MapServer", "visibility": false, "opacity": 0.6, //"visibleLayers": [], //"minScale": 100000, //"maxScale": 0, "title": "Community-Based Planning Areas", "id": "cpa", "description": null },
function addPrint() { var layoutOptions = { 'authorText': configOptions.owner, 'titleText': configOptions.title, 'scalebarUnit': (i18n.viewer.main.scaleBarUnits === 'english') ? 'Miles' : 'Kilometers', //'legendLayers': [] //comment out so the legend will display by default, 6/13/13 jms. }; //TODO - replace default templates with info from service var templates = dojo.map(configOptions.printlayouts, function (layout) { layout.layoutOptions = layoutOptions; return layout; }); // print dijit var printer = new esri.dijit.Print({ map: map, templates: templates, url: configOptions.helperServices.printTask.url }, dojo.create('span')); dojo.query('.esriPrint').addClass('esriPrint'); dojo.byId('webmap-toolbar-center').appendChild(printer.printDomNode); printer.startup(); }
Solved! Go to Solution.
I would love to -- but how do I do that? Sorry, the obvious things evade me sometimes...
function addPrint() { var legendLayer = new esri.tasks.LegendLayer(); legendLayer.layerId = "defaultBasemap"; var layoutOptions = { 'authorText': configOptions.owner, 'titleText': configOptions.title, 'scalebarUnit': (i18n.viewer.main.scaleBarUnits === 'english') ? 'Miles' : 'Kilometers', 'legendLayers': [legendLayer] }; //TODO - replace default templates with info from service var templates = dojo.map(configOptions.printlayouts, function (layout) { layout.layoutOptions = layoutOptions; return layout; }); // print dijit var printer = new esri.dijit.Print({ map: map, templates: templates, url: configOptions.helperServices.printTask.url }, dojo.create('span')); dojo.query('.esriPrint').addClass('esriPrint'); dojo.byId('webmap-toolbar-center').appendChild(printer.printDomNode); printer.startup(); }
var legendLayers = []; //use the same filtered list created in the 'buildLayerVisibleList' function in the legend dijit, added 5/23/13 jms function buildLayerVisibleList(layers) { console.log("--> inside buildLayerVisibleList"); var layerInfos = []; dojo.forEach(layers, function (mapLayer, index) { console.log("mapLayer.title: " + mapLayer.title + ", mapLayer.id: " + mapLayer.id); //If layer is for viewing popup info only, do not add to layer list. added 5/23/13 jms. //The id of the layer must start with 'pop' to filter it out. var isPopupLyr = false; if (mapLayer.id.substring(0,3) == "pop") { isPopupLyr = true} ; console.log("isPopupLyr: " + isPopupLyr); //Only include layers that are not used solely for 'popups', added 5/23/13 jms if (isPopupLyr == false) { if (mapLayer.featureCollection && !mapLayer.layerObject) { if (mapLayer.featureCollection.layers) { //add the first layer in the layer collection... not all - when we turn off the layers we'll //turn them all off if (mapLayer.featureCollection.layers) { layerInfos.push({ "layer": mapLayer, "visible": mapLayer.visibility, "title": mapLayer.title }); } } } else if (mapLayer.layerObject) { layerInfos.push({ layer: mapLayer.layerObject, visible: mapLayer.layerObject.visible, title: mapLayer.title }); } } }); legendLayers = layerInfos; //set global var for use with the legend dijit, added 5/23/13 jms return layerInfos; }
function addPrint() { console.log("--> inside addPrint function"); //legendLayers global var set in the buildLayerVisibleList fn. //Array contains layer object, visible setting, and title. console.log("legendLayers.length: " + legendLayers.length); //Create array containing the layer objects ids. var layerIds = []; //Loop thru each layer object and push id into the new array. for (var i = 0; i < legendLayers.length; i++) { //var layer = layers; console.log("legendLayers.layer.id: " + legendLayers.layer.id); var legendLyr = new esri.tasks.LegendLayer(); legendLyr.layerId = legendLayers.layer.id layerIds.push(legendLyr); } console.log("layerIds.length: " + layerIds.length); var layoutOptions = { 'authorText': configOptions.owner, 'titleText': configOptions.title, 'scalebarUnit': (i18n.viewer.main.scaleBarUnits === 'english') ? 'Miles' : 'Kilometers', //'legendLayers': [] //comment out so the legend will display by default, 6/13/13 jms. But this won't print the legend for tiled services... //'legendLayers': [legendLayer] 'legendLayers': layerIds //set to the layer id array }; //TODO - replace default templates with info from service var templates = dojo.map(configOptions.printlayouts, function (layout) { layout.layoutOptions = layoutOptions; return layout; }); // print dijit var printer = new esri.dijit.Print({ map: map, templates: templates, url: configOptions.helperServices.printTask.url }, dojo.create('span')); dojo.query('.esriPrint').addClass('esriPrint'); dojo.byId('webmap-toolbar-center').appendChild(printer.printDomNode); printer.startup(); }
Thanks for leading me in the right direction.
This is definitely a bug in Esri's code. According to the documentation:
If legendLayers is not specified, all operational layers will be present in the legend.
I recently encountered this problem and came up with this function to createLegend Layers.
* Creates an array of LegendLayers of all layers currently visible in the map.
* @param {esri.Map} map
* @returns {esri.tasks.LegendLayer[]}
function getLegendLayersFromMap(map) {
var layer, legendLayer, output = [];
for (var i = 0, l = map.layerIds.length; i < l; i += 1) {
layer = map.getLayer(map.layerIds);
if (layer.visible && layer.visibleAtMapScale) {
legendLayer = new LegendLayer();
legendLayer.layerId = layer.id;
if (layer.visibleLayers) {
legendLayer.subLayerIds = layer.visibleLayers;
output.push(legendLayer);
// Return null if the output array has no elements.
return output.length > 0 ? output : null;
// Sample call
var printParameters = new PrintParameters();
printParameters.map = map;
var template = new PrintTemplate();
template.format = "PDF";
// printUI is a custom class in my app that creates and manages the HTML UI for a print task form.
template.layout = printUI.getSelectedTempalteName();
template.layoutOptions = {
authorText:printUI.form.querySelector("input[name=author]").value,
titleText: printUI.form.querySelector("input[name=title]").value,
legendLayers: getLegendLayersFromMap(map)
printParameters.template = template;
printTask.execute(printParameters);
/** * Creates an array of LegendLayers of all layers currently visible in the map. * @param {esri.Map} map * @returns {esri.tasks.LegendLayer[]} */ function getLegendLayersFromMap(map) { var layer, legendLayer, output = []; for (var i = 0, l = map.layerIds.length; i < l; i += 1) { layer = map.getLayer(map.layerIds); if (layer.visible && layer.visibleAtMapScale) { legendLayer = new LegendLayer(); legendLayer.layerId = layer.id; if (layer.visibleLayers) { legendLayer.subLayerIds = layer.visibleLayers; } output.push(legendLayer); } } // Return null if the output array has no elements. return output.length > 0 ? output : null; } // Sample call var printParameters = new PrintParameters(); printParameters.map = map; var template = new PrintTemplate(); template.format = "PDF"; // printUI is a custom class in my app that creates and manages the HTML UI for a print task form. template.layout = printUI.getSelectedTempalteName(); template.layoutOptions = { authorText:printUI.form.querySelector("input[name=author]").value, titleText: printUI.form.querySelector("input[name=title]").value, legendLayers: getLegendLayersFromMap(map) }; printParameters.template = template; printTask.execute(printParameters);
Agreed (somewhat)...a look at _createOperationalLayers in PrintTask.js of v3.9 of the JavaScript API shows a switch for which there is no case for "esri.layers.ArcGISTiledMapService". I think it's only a bug, though, if omitting this type of layer was unintentional. However, I can't think of any good reason as to why they would omit it. Whatever the case, their own documentation is, at minimum, misleading.
I don't know if you had success with this, but were you able to have the legend appear in more than 1 column inside your print template? I have my map being printed to the custom template I made and the legend is also appearing but the problem is that it appears as 1 column and goes behind the map. I'd like to make it a 2 or 3 column legend so it spreads width-wise.
Alexei
