Locate Button Will Not Find Location
5868
16
10-30-2013 10:14 AM
NathanSommers
New Contributor III
I'm in the process of creating a web editing application by modifying some of the javascript examples.  I have added LocateButton into the app however when I click on the button it just spins.  It's not my browser because the examples work just fine.  Here is my code:
    <script>
      require([
        "dojo/ready",
        "dojo/parser",
        "dijit/layout/BorderContainer",
        "dijit/layout/ContentPane",
        "esri/map",
        "esri/dijit/LocateButton",
        "esri/config",
        "esri/tasks/GeometryService",
        "esri/urlUtils",
        "esri/arcgis/utils",
        "dojo/dom",
        "dojo/_base/array",
        "esri/dijit/editing/Editor",
        "dojo/domReady!"
        ], function(
          ready,
          parser,
          BorderContainer,
          ContentPane,
          Map,
          LocateButton,
          config,
          GeometryService,
          urlUtils,
          arcgisUtils,
          dom,
          array,
          Editor
          ready(function(){
            parser.parse();
            config.defaults.io.proxyUrl = "/proxy";
            config.defaults.geometryService = new GeometryService("http://maps.ci.perrysburg.oh.us/arcgis/rest/services/Utilities/Geometry/GeometryServer");
            //check to see if a webmap was specified using URL params. If not use the
            //hardcoded webmap id
            var urlObject = urlUtils.urlToObject(document.location.href);
            var webmap = "90d7e213fb014d31ac623d233511fcf9";
            if(urlObject.query && urlObject.query.webmap){
              webmap = urlObject.query.webmap;
            //create the map
            arcgisUtils.createMap(webmap, "map", {
              mapOptions: {
                sliderStyle: "large"
              ignorePopups: true
            }).then(function(response){
              var map = response.map;
                dom.byId("title").innerHTML = response.itemInfo.item.title;
                dom.byId("snippet").innerHTML = response.itemInfo.item.snippet;
              geoLocate = new LocateButton({
               map: map,
               geolocationOptions: {
                      maximumAge: 0,
                      timeout: 15000,
                      enableHighAccuracy: true
              }, "LocateButton");
                //create the editor widget
                var layerInfo = [];
                var layers = response.itemInfo.itemData.operationalLayers;
                array.forEach(layers, function (layer){
                  layerInfo.push({
                    "featureLayer": layer.layerObject
                var settings = {
                  map: map,
                  layerInfos: layerInfo
                var editorWidget = new Editor({
                  settings: settings
                },"editorDiv");
                editorWidget.startup();
    </script>
Any help would be much appreciated!
Thank you,
Ian
NathanSommers
New Contributor III
Thanks I just figured it out.  It was a projection issue.
Watching the traffic I saw this:
Map: Geometry (wkid: 102100) cannot be converted to spatial reference of the map (wkid: 102722)
I'm using a basemap that I published on ArcGIS Online which has a State Plane Ohio North projection.  I changed it to an ArcGIS Onilne basemap with a Web Mercator projection and everything worked fine.
Does anybody know how I would be able to use a non Web Mercator projection with the Locate Widget?
NumaGremling
Are you running it from your server or straight from disk? Always make sure you run it from a server, since some of the functionality will only work otherwise. I've had issues with certain widgets before until I put them into my root directory.
Also, I just looked at mine, and I have an additional line. In your code it would look like this:
               map: map,
                      maximumAge: 0,
                      timeout: 15000,
              }, "LocateButton");
             geoLocate.startup();
EDIT:
Nevermind! You forgot to declare a variable. This should fix it:
var geoLocate = new LocateButton({
NathanSommers
New Contributor III
Thanks for the quick reply.
I tried making both changes you suggested however neither worked.  I am also running it from my root directory.  When I download the sample from https://developers.arcgis.com/en/javascript/jssamples/widget_locate.html and run it from my root directory everything works fine.  I just run into problems when I'm trying to implement the locateButton in another site.
Thanks for your help,
Ian
NumaGremling
I was using the same sample, and I ended up with this, which works:
  var userLocation = new LocateButton({
  map: mainMap
  }, "userLocDIV");
  userLocation.startup();
The only difference I see is that you included geolocationOptions. I've tried adding yours to mine and it still worked, but maybe you still want to take them out and see what happens.
JanelYang
New Contributor III
Ian,
Which browser are you using? There is a known issue with LocateButton on Firefox. Here is an earlier discussion about it: http://forums.arcgis.com/threads/95213-quot-Find-my-location-quot-is-not-working-in-firefox. Let us know if it helps!
NathanSommers
New Contributor III
Hi Jerome,
I've tried it in Chrome, IE 9, Safari, and Firefox both with and without the fix outlined in the thread and still nothing.
GISDev1
Occasional Contributor III
What is the http traffic telling you about the request and response for the geolocation?
NathanSommers
New Contributor III
GISDev1
Ok, that's a good start.
What geometry service are you pointing to? Yours or esri's or a custom one?
And what geocoder are you pointing to in order to geolocate the addresses?
FrancoisPelletier1
Did you manage to find a solution or workaround ?
I came across the exact same issue. I'm also using my own basemap wich is a non Web Mercator projection. I feel like the LocateButton widget just does'nt support using another projection... The console message comes from the api's init.js file.
d._canProject(c)?d.isWebMercator()?b=O.geographicToWebMercator(b):4326===d.wkid&&(b=O.webMercatorToGeographic(b,!0)):(console.log("Map: "+v.substitute({geometry:c.wkid||c.wkt,map:d.wkid||d.wkt},this.invalidGeometry)),b=null))
I would very much like to avoid the pain of building my own Locate widget.
Please help !
