Map Gallery template
652
02-16-2012 03:06 AM
BillEveringham
I am currently using a map gallery template, but am having trouble when zooming to and address. I know it has something to do with my tiled basemap. I want to be able to zoom to selection/location when I put in an address without the basemap disappearing. Is there away to Any suggestions would be appreciated. I tried changing the selected text below, but that didn't work. I ultimately would like use one of the LOD's from my rest endpoint... http://gis.arlingtonva.us/ArcGIS/rest/services/Arlington_Basemap_Plain/MapServer?f=json&pretty=true
// ZOOM TO LOCATION: ZOOMS MAP TO LOCATION POINT
function zoomToLocation(x, y, IPAccuracy){
// calculate lod
var lod = 14;
// set point
var pt = esri.geometry.geographicToWebMercator(new esri.geometry.Point(x, y));
// IF LOCATE RESULTS
if(locateResultLayer) {
locateResultLayer.clear();
else{
locateResultLayer = new esri.layers.GraphicsLayer();
map.addLayer(locateResultLayer);
var pointSymbol = new esri.symbol.PictureMarkerSymbol("graphics/ui/bluepoint-21x25.png", 21, 25).setOffset(0,12);
var locationGraphic = new esri.Graphic(pt,pointSymbol);
locateResultLayer.add(locationGraphic);
// zoom and center
map.centerAndZoom(pt,lod);
