Map Service Suddenly Requires Password
650
5
09-25-2013 06:49 AM
MichaelGlassman2
New Contributor III
I have been working with the ArcGIS JavaScript API for a few months using the same HTML file. Without changing any code, I am required to input my username and password when I open the HTML file in a browser but previously I did. Is there a setting in the Server Manager or just a change in API that might have caused this change to happen? I would like to be able to open the HTML file without entering in my password each time. Thanks
ZachLiu1
Occasional Contributor II
Check your web service from ArcGIS Server Manager.
If you see a small lock icon, click it to open security setting and set it to public.
If you haven't changed anything, that maybe the problem.
JohnGravois
zach is right on the mark, i've seen a few cases in which server manager needed to be reminded that all services were public after an unexpected shutdown.
MichaelVolz
Esteemed Contributor
Is this a bug with ArcGIS Server software?  If so, what version(s) does this affect?
ZachLiu1
I think it is a bug. I have met this problem before- services turn from public to private without any notice, maybe after a shutdown as John mentioned.
The version I used is 10.1.
JohnGravois
i personally don't log bugs until i've been able to reproduce an error :).
i agree that it seems inappropriate that ArcGIS Server would ever choose to enforce security on a site when it wasn't previously enforced, but given the simplicity of resolving the problem, the behavior seems a lot more desirable than if ArcGIS Server chose to make sensitive resources public when it started up incorrectly.
