Measure Widget Issue - ArcGIS Javascript API 3.11
3267
11
10-07-2014 09:50 AM
by Anonymous User
Not applicable
I am having an issue with the Measure Widget in my application after updating to 3.11. The widget does not appear after the application loads. I have checked my code and do not see an issue, also when reverting back to 3.10 it works correctly.
Has anyone else had this issue after updating to 3.11?
measurement = new Measurement({
    map: map
}, dom.byId("measure_results"));
measurement.startup();
JonathanUihlein
For the most part, this only happens when the parser is called at the wrong time.
JoshHevenor
Occasional Contributor II
Thanks Jonathan,
It turns out that this tool uses the map.graphics layer to draw its markers, etc. I had a click handler on that layer that was interfering so I moved all my stuff to my own graphics layer and the measure tool works fine now.
