Bart,
Here is a sample. Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title>Measure Tool</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.21/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.21/esri/css/esri.css">
<style>
html,
body {
height: 100%;
width: 100%;
margin: 0;
body {
background-color: #FFF;
overflow: hidden;
font-family: "Trebuchet MS";
#map {
border: solid 2px #808775;
-moz-border-radius: 4px;
-webkit-border-radius: 4px;
border-radius: 4px;
margin: 5px;
padding: 0px;
#titlePane {
width: 240px;
.claro .dijitTitlePaneTitle {
background: #fff;
font-weight: 600;
border: none;
border-bottom: solid 1px #29201A;
border-top: solid 1px #29201A;
.claro .dijitTitlePaneTitleHover {
background: #eee;
.claro .dijitTitlePaneTitleActive {
background: #808775;
.claro .dijitTitlePaneContentOuter {
border-right: none;
border-bottom: none;
border-left: none;
</style>
<script src="http://js.arcgis.com/3.21/"></script>
<script>
var map, deleteMGra;
require([
"dojo/dom",
"esri/Color",
"dojo/keys",
"dojo/parser",
"dojo/query",
"dojo/on",
"dojo/dom-construct",
"dojo/_base/array",
"dojo/dom-style",
"esri/config",
"esri/sniff",
"esri/map",
"esri/SnappingManager",
"esri/dijit/Measurement",
"esri/layers/FeatureLayer",
"esri/layers/GraphicsLayer",
"esri/graphic",
"esri/renderers/SimpleRenderer",
"esri/tasks/GeometryService",
"esri/symbols/SimpleLineSymbol",
"esri/symbols/SimpleFillSymbol",
"esri/symbols/PictureMarkerSymbol",
"esri/dijit/Scalebar",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dijit/TitlePane",
"dijit/form/CheckBox",
"dojo/domReady!"
], function (
dom, Color, keys, parser, query, on, domConstruct, array, domStyle,
esriConfig, has, Map, SnappingManager, Measurement, FeatureLayer, GraphicsLayer, Graphic,
SimpleRenderer, GeometryService, SimpleLineSymbol, SimpleFillSymbol, PictureMarkerSymbol
parser.parse();
esriConfig.defaults.io.proxyUrl = "/proxy/";
esriConfig.defaults.io.alwaysUseProxy = false;
esriConfig.defaults.geometryService = new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
map = new Map("map", {
basemap: "satellite",
center: [-85.743, 38.256],
zoom: 17
var sfs = new SimpleFillSymbol(
"solid",
new SimpleLineSymbol("solid", new Color([195, 176, 23]), 2),
null
var parcelsLayer = new FeatureLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_LandRecords_Louisville/MapServer/0", {
mode: FeatureLayer.MODE_ONDEMAND,
outFields: ["*"]
parcelsLayer.setRenderer(new SimpleRenderer(sfs));
map.addLayers([parcelsLayer]);
var snapManager = map.enableSnapping({
snapKey: has("mac") ? keys.META : keys.CTRL
var layerInfos = [{
layer: parcelsLayer
snapManager.setLayerInfos(layerInfos);
var measureGL = new GraphicsLayer();
var pms = new PictureMarkerSymbol('http://js.arcgis.com/3.21/esri/dijit/images/esriGreenPin16x26.png', 16, 26);
pms.setOffset(0, 12);
map.addLayers([measureGL]);
var measurement = new Measurement({
map: map,
}, dom.byId("measurementDiv"));
measurement.startup();
measurement.on("tool-change", function (evt) {
if (evt.toolName !== "location") {
measureGL.clear();
var rows = query(".myMeasurementTableRow");
array.forEach(rows, function (row) {
domConstruct.destroy(row);
measureGL.hide();
} else {
measureGL.show();
var mRows = query(".esriMeasurementTableRow");
domStyle.set(mRows[1], "display", "");
measurement.on("measure", function (evt) {
switch (evt.toolName) {
case "location":
break;
default:
var resultDiv = query(".dijitContentPane .esriMeasurementResultValue")[0];
console.info(measurement);
var result = domConstruct.toDom("<div class='result'>" + evt.values[0] + "<div>");
domConstruct.place(resultDiv, result);
break;
deleteMGra = function (){
var rowId = this.event.target.id;
domConstruct.destroy(this.event.target.id);
measureGL.graphics.some(function(g){
if(g.attributes.Id === rowId){
measureGL.remove(g);
if(measureGL.graphics.length == 0){
measurement.clearResult();
return true;
measurement.on("measure-end", function (evt) {
case "location":
var tbl = query(".esriMeasurementResultTable tbody")[0];
var eRows = query(".esriMeasurementTableRow");
var mRows = query(".myMeasurementTableRow");
var rowId = "mrowid" + (mRows.length + 1 ).toString();
var row = domConstruct.toDom("<tr class='myMeasurementTableRow' id='" + rowId + "'>" +
"<td><img src='http://js.arcgis.com/3.14/esri/dijit/images/esriGreenPin16x26.png' style='vertical-align:middle'></td>" +
"<td class='esriMeasurementTableCell'>" + evt.values[0] + "</td><td class='esriMeasurementTableCell'>" + evt.values[1] +
"</td><td><span style='cursor:pointer;color:red;font-weight:bold;padding:0 2px;' id='" + rowId + "'" +
" onClick='deleteMGra()'>X</span></td></tr>");
domStyle.set(eRows[1], "display", "none");
domConstruct.place(row, tbl);
measureGL.add(new Graphic(evt.geometry, pms, {
"Lat": evt.values[0],
"Lon": evt.values[1],
"Id": rowId
measurement._measureGraphics[0]._graphicsLayer.clear();
break;
default:
var resultDiv = query(".esriMeasurementResultValue")[0];
break;
</script>
</head>
<body class="claro">
<div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width:100%; height:100%;">
<div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'">
<div style="position:absolute; right:20px; top:10px; z-Index:999;">
<div id="titlePane" data-dojo-type="dijit/TitlePane" data-dojo-props="title:'Measurement', closable:'false', open:'false'">
<div id="measurementDiv"></div>
<span style="font-size:smaller;padding:5px 5px;">Press <b>CTRL</b> to enable snapping.</span>
</div>
</div>
</div>
</div>
</body>
</html>
