I want use a MediaContent popup element contains a chart with line's type or column's type or bar 's type and with a series propertie (ChartMediaInfoValueSeries[]).
https://developers.arcgis.com/javascript/latest/api-reference/esri-popup-content-support-ChartMediaI...
https://developers.arcgis.com/javascript/latest/api-reference/esri-popup-content-BarChartMediaInfo.h...
https://developers.arcgis.com/javascript/latest/api-reference/esri-popup-content-ColumnChartMediaInf...
https://developers.arcgis.com/javascript/latest/api-reference/esri-popup-content-LineChartMediaInfo....
I want an array for ChartMediaInfoValueSeries[] with my custom values.
However, I don't understand the help and how it works and there is no sample.
Here it is my sample :
https://codepen.io/blaurancin/pen/xxWrQMW?editors=1000
https://codepen.io/blaurancin/live/xxWrQMW
<html dir="ltr">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
<title>Line Chart | ArcGIS API for JavaScript 4.24</title>
<link rel="stylesheet" href="https://js.arcgis.com/4.24/esri/themes/light/main.css" />
<script src="https://js.arcgis.com/4.24/"></script>
<style>
html,
body,
#mapDiv {
height: 100%;
width: 100%;
margin: 0;
padding: 0;
</style>
<script>
require(["esri/Map", "esri/views/MapView", "esri/layers/FeatureLayer", "esri/core/reactiveUtils"],
(Map, MapView, FeatureLayer, reactiveUtils) => {
// setup the map
const map = new Map({
basemap: "hybrid"
const view = new MapView({
container: "mapDiv",
map: map,
center: [-81.31557659295213, 48.12557766494745],
zoom: 6,
popup: {
dockEnabled: true,
dockOptions: {
buttonEnabled: false,
breakpoint: false
const featureLayer = new FeatureLayer({
url: "https://services.arcgis.com/6iGx1Dq91oKtcE7x/ArcGIS/rest/services/Census_Data/FeatureServer/2",
popupTemplate: {
title: "Chart",
content: [
// // It is also possible to set the fieldInfos outside of the content
// // directly in the popupTemplate. If no fieldInfos is specifically set
// // in the content, it defaults to whatever may be set within the popupTemplate.
// type: "fields", // FieldsContentElement
// fieldInfos: [{
// fieldName: "Population ",
// visible: false,
// label: "Population",
// format: {
// places: 0,
// digitSeparator: true
// fieldName: "LaborForce",
// visible: false,
// label: "LaborForce",
// format: {
// places: 0,
// fieldName: "Household",
// visible: false,
// label: "Household",
// format: {
// places: 0,
// fieldName: "Job",
// visible: false,
// label: "Job",
// format: {
// places: 0,
type: "media",
mediaInfos: [{
title: "<b>Chart</b>",
type: "line-chart",
caption: "",
value: {
// fields: ["Population", "LaborForce", "Household", "Job"],
series: [{fieldName: "val1", value: 10}, {fieldName: "val2", value: 50}, {fieldName: "val3", value: 100}, {fieldName: "val4", value: 150}, {fieldName: "val1", value: 200},],
normalizeField: null,
tooltipField: ""
outFields: ["*"]
map.add(featureLayer);
// reactiveUtils.when(
// () => view?.stationary === true,
// async () => {
// console.log(view);
</script>
</head>
<body>
<div id="mapDiv"></div>
</body>
</html>
Please, could you help me ?
How can I use my own values (without a field) for media's type of a popup ?
Thank you so much for your help,
Bertrand
