Mouse-over a FeatureLayer represented by a dashed line
1636
11-23-2015 02:38 PM
JoshVan_Kylen
We have a feature displayed as a dashed red line.  This causes the mouse-over to only register when over a red dash but not over the missing/transparent part of the line.   Does anyone have a solution for this situation?
So far all I have come up with is to add a 2nd version of this FeatureLayer with a solid line and make it transparent.  But this causes complications with the TOC widget.  If the user turns this layer off they can still get a mouse-over when they did not expect one.
RickeyFight
MVP Regular Contributor
Josh,
Try
path {
   stroke-opacity: .1;
   stroke-width: 5px;
   fill-opacity: .5;
JoshVan_Kylen
Thanks Rickey, but that did not produce the desired affect. The mouse-over popup still disappears when the mouse is over a gap in the dashed line.  Additionally since it is applied to all the paths on the screen it affects other features.
Before adding the suggested path style:
With the added path styling:
RickeyFight
Josh,
I believe that is what I did here:
http://gis.ashland.or.us/ashlandparksandrec/
I will look and see if there is another solution though
