onmouseover on esri js api 4
654
09-14-2016 03:49 PM
JordanEM
How to handle the mouseover on mapview, map any object and use event.x and y to display the map info
i tried the following
view.container.onmouseover = function (event) {
var sp = new ScreenPoint();
sp.x = event.x;
sp.y = event.y;
view.hitTest(sp).then(function (response) {
var graphics = response.results;
graphics.forEach(function (graphic) {
console.log(graphic);
but if the map is contained on page.that has header or another html element the event of x ,y is not correct
Tags (1)
JohnGrayson
This is what I do before calling 'toMap()'...
toMapPoint: function (evt) {
 var adjustedX = evt.clientX - this.view.position[0];
 var adjustedY = evt.clientY - this.view.position[1];
 return this.view.toMap(adjustedX, adjustedY);
