Open an popup template from another pop-up template
679
02-11-2019 05:12 AM
ShaikhRizuan
New Contributor III
I want to open esri popup template from popup template on click of table data, Please find below image:
I want to show some charts related to feature layer, on click of table data as shown below:
Regards,
Shaikh Rizuan
RobertScheitlin__GISP
Shaikh,
   I do not have any code samples for your desired workflow but what is happening in your video you provided is that the feature has a click event that triggers a html element to be added to the app or an html element is set to visible. Not really anything to do with the maps popup.
Shaikh,
  A popup is a singleton class for the map, meaning you can only have one popup visible.
ShaikhRizuan
New Contributor III
Hi Robert,
Is there any other way around to get that kind of functionality, I want to implement in one of the widget of  WAB (2.6). I have attached  .gif file which i found in one of the ESRI link.
Sample App
How can i achieve the above functionality?
Shaikh,
