Renee,You don't need to perform a significant re-write to upgrade to 3.0. Here's a version of your sample that works for me that uses 3.0 with the 1.6 style syntax:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
<meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
<title>Dojo Dropdown Demo</title>
<link rel="stylesheet" href="https://community.esri.com//serverapi.arcgisonline.com/jsapi/arcgis/3.0/js/dojo/dijit/themes/claro/claro.css">
<!-- ArcGIS API for JavaScript -->
<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.0compact"></script>
<script type="text/javascript">
dojo.require("esri.map");
dojo.require("esri.tasks.Query");
dojo.require("dijit.form.FilteringSelect");
dojo.require("dojo.data.ItemFileReadStore");
dojo.addOnLoad(init);
var map,queryTask;
function init() {
queryTask = new esri.tasks.QueryTask("http://armstrong.uww.edu/ArcGIS/rest/services/NewCampus/MapServer/27");
map = new esri.Map("map");
dojo.connect(map, "onLoad", function() {
//populate dropdown
executeQuery();
// Add the campus basemap
var campusMap = new esri.layers.ArcGISTiledMapServiceLayer('http://armstrong.uww.edu/ArcGIS/rest/services/NewCampus/MapServer');
map.addLayer(campusMap);
function executeQuery() {
//execute the query task then populate the dropdown menu with list of building names
var query = new esri.tasks.Query();
query.returnGeometry = true;
query.outFields = ["BldgName","FID"];
query.where = "1=1";
queryTask.execute(query,populateMenu);
function populateMenu(featureSet){
var items = dojo.map(featureSet.features, function (item) {
return {
var data = {
identifier:"id",
items:items
var objStore = new dojo.data.ItemFileReadStore({data:data});
var filteringSelect = new dijit.form.FilteringSelect({
style:'width:300px;',
placeHolder:'Select a building or start typing',
store:objStore,
required:false,
labelAttr:'name',
fetchProperties:{sort:[{attribute:'name'}]},
onChange:function(val){
if(val){
var selectQuery = new esri.tasks.Query();
selectQuery.returnGeometry = true;
selectQuery.objectIds = [val];
queryTask.execute(selectQuery,function(featureSet){
map.graphics.clear(); //clear any existing map graphics
//get the first feature and add to map
if(featureSet.features.length > 0){
var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID,
new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID,
new dojo.Color([255,0,0]), 2),new dojo.Color([255,255,0,0.25]));
var feature = featureSet.features[0];
var graphic = new esri.Graphic(feature.geometry,symbol);
map.graphics.add(graphic);
},'bldgSelect');
</script>
</head>
<body class='claro' style="font-family: Arial Unicode MS,Arial,sans-serif;">
<input id='bldgSelect'/>
<div id="wrapper" style="position: relative; width: 700px; height: 500px; border:1px solid #000;">
<!-- Map canvas -->
<div id="map" style="position: absolute; width: 700px; height: 500px; z-index: 1;"></div>
</div>
</body>
</html>
Thanks for directing me to that sample, that's what I've been hunting for. I wish they hadn't buried it there but at least it's a start.
I'm disappointed that I will apparently have to significantly rewrite and restructure pretty much all of my code on all of my sites with the new release. The differences are substantial.
