I'm using the popupTemplate for displaying attributes for a feature and I'm trying to display the alias as the label, figured it should be pretty easy... Here is what the docs says about it:fieldInfos[INDENT]<String> label The label to display, the default value is the field alias.[/INDENT]http://help.arcgis.com/en/webapi/javascript/arcgis/help/jshelp_start.htm#jshelp/intro_popuptemplate....Reading that I would think I should be able to declare the fieldInfos as follows and the alias should be displayed as the label:var popupTemplate = new esri.dijit.PopupTemplate({
title: "{address}",
fieldInfos: [
{fieldName: "req_type", visible:true},
{fieldName: "req_date", visible:true,format:{dateFormat:'shortDateShortTime'}}
showAttachments:true
But this is not the case, it still displays the field name. Below is a sample I altered to show what is happening. <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=7, IE=9" />
<!--The viewport meta tag is used to improve the presentation and behavior of the
samples on iOS devices-->
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
<title>
San Francisco
</title>
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/dojo/dijit/themes/claro/claro.css"/>
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/esri/dijit/css/Popup.css"/>
<style>
html, body { height: 100%; width: 100%; margin: 0; padding: 0; } .esriScalebar{
padding: 20px 20px; } #map{ padding:0;}
</style>
<script type="text/javascript">
var dojoConfig = {
parseOnLoad: true
</script>
<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.5">
</script>
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("esri.map");
dojo.require("esri.layers.FeatureLayer");
dojo.require("esri.dijit.Popup");
var map;
function init() {
esri.config.defaults.geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
//setup the map's initial extent (World View)
var initExtent = new esri.geometry.Extent({
"xmin":-13631589,
"ymin":4549150,
"xmax":-13630075,
"ymax":4549635,
"spatialReference":{"wkid":102100}
//define custom popup options
var popupOptions = {
'markerSymbol': new esri.symbol.SimpleMarkerSymbol('circle', 32, null, new dojo.Color([0, 0, 0, 0.25])),
'marginLeft': '20',
'marginTop': '20'
//create a popup to replace the map's info window
var popup = new esri.dijit.Popup(popupOptions, dojo.create("div"));
map = new esri.Map("map", {
extent: initExtent,
infoWindow: popup
//Add the topographic layer to the map. View the ArcGIS Online site for services http://arcgisonline/home/search.html?t=content&f=typekeywords:service
var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
map.addLayer(basemap);
//define a popup template
title: "{address}",
fieldInfos: [
//create a feature layer based on the feature collection
var featureLayer = new esri.layers.FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/SanFrancisco/311Incidents/MapServer/0", {
mode: esri.layers.FeatureLayer.MODE_SNAPSHOT,
infoTemplate: popupTemplate,
outFields: ['req_date','address']
featureLayer.setDefinitionExpression("address != ''");
dojo.connect(featureLayer,"onClick",function(evt){
map.infoWindow.setFeatures([evt.graphic]);
map.addLayer(featureLayer);
dojo.connect(map, 'onLoad', function(theMap) {
//resize the map when the browser resizes
dojo.connect(dijit.byId('map'), 'resize', map,map.resize);
dojo.ready(init);
</script>
</head>
<body class="claro">
<div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline'"
style="width: 100%; height: 100%; margin: 0;">
<div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'"
style="border:1px solid #000;padding:0;">
</div>
</div>
</body>
</html>
When I identify it still shows the field name as the label, attached is a screenshot. I would expect it to show Request ID and Request Type as defined in the service. Am I doing something wrong or is this a bug? Is there an easy fix for this?I know I'm able to declare the label explicitly for the fields, but I don't want to have to maintain those when clients want them changed. Thanks,Ryan
