Print legend on map
3522
12
09-26-2016 05:42 AM
BrianFoley1
New Contributor II
I am trying to print my map with it's legend and am having an issue with the legend not showing up.  This is my code : https://jsfiddle.net/befoley/vxmfatw1/17/ . (For some reason, I can't get the printout to show when running it in JSFiddle)  This is what my map looks like when I run it on my server :
And this is what the printout looks like :
 I can't figure why my legend doesn't appear on the printout.  Can anyone provide some suggestions.  Thanks.
ShruthiSrinivasan1
New Contributor III
Robert,
I used the standard print service (print widget) and the layer headings are still not displayed. Besides the vertical spacing between the legend items, everything is the same.
ShruthiSrinivasan1
New Contributor III
Robert, I have also attached screenshots from the app's print output (using print task) and the legend from the map service.
Print task output from the app
RobertScheitlin__GISP
I can't say I know how to achieve what you are looking for.
