I have a feature layer showing nursing facilities and I have added label layer that show Facility IDs. I need labels only for the map printout, I do not want the labels on the map, because I already have hover over function to identify the features. I had set scale dependency on (commented out) the labels but that did not work because what I want is for the nursing facilities ID should show on the print out at any scale, so the facility IDs need to show up on the printed map regardless of scale or zoom level.
I am trying to find out if there is a way to have labels show up only when the print function is turned on or have way for the labels to be included in the PDF printout. I looked at samples and reference for label layer and label class and could not much to help me.
It will be great if I can get some help or pointers on how get this accomplished.
Thanks for the help!!
