Print widget, FeatureLayer, Legend not displaying properly
595
09-07-2017 03:48 PM
KevinAndras
Hi, I'm working on an application with the latest (4.4) API.  I user a REST QueryTask to generate a FeatureLayer, which gets added to the map, and a SimpleRenderer is generated using the range of values for whatever attribute the user has selected.  The legend is added to the map.  An example is shown in screenshot1.
When I use the Print function, the legend shows up as individual entries for each feature, with a caption that says Override 1, Override 2, etc. for each feature that is visible in the map view.   Screenshot2 shows the output from Print.
Any clue what I could be doing wrong?  Thanks!
