Print widget in JS 4.24 not printing with tile layer
386
02-03-2024 04:30 AM
mmkmmkv
New Contributor II
in version 4.24, print widget not printing with Tile layer as basemap, shows error, it prints without tile layer, any solution to print with tile layer?
Noah-Sager
Hi @mmkmmkv, thanks for posting your question here. The current version is 4.28, so this issue may have been fixed at a more recent release. If you can share a reproducible test app that shows the error, we could take a look. I'd also recommend looking at our known print limitations for guidance:
https://developers.arcgis.com/javascript/latest/api-reference/esri-rest-print.html
mmkmmkv
New Contributor II
@Noah-Sager this is layerType":"ArcGISTiledMapServiceLayer" which is added as basemap which is published as tiled layer which is a image, also this is not working in 4.28, for this any permission needed for print as pdf, png, etc?
Also, when added as MapImageLayer, it shows error as, message: "Unable to load image: https://.../MapServer/export"
Is any export permission required?
I just checked Image Tile layer its spatial reference is 3857 but published tile layer has spatial reference of 4326, does it make a difference?
In export url, i tried below url:
https://.../MapServer/export?bbox=(SPECIFY_BBOX_HERE_OF_3857)&bboxSR=3857&layers=&layerDefs=&size=&imageSR=4326&historicMoment=&format=gif&transparent=false&dpi=&time=&timeRelation=esriTimeRelationOverlaps&layerTimeOptions=&dynamicLayers=&gdbVersion=&mapScale=&rotation=&datumTransformations=&layerParameterValues=&mapRangeValues=&layerRangeValues=&clipping=&spatialFilter=&f=html
how & where to specify imageSR in print service for export? or bboxSR? if required
mmkmmkv
New Contributor II
<html>
<head>
    <meta charset="utf-8" />
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
    <title>Print widget | Sample | ArcGIS API for JavaScript 4.24</title>
    <link rel="stylesheet" href="https://js.arcgis.com/4.24/esri/themes/light/main.css" />
    <style>
        html,
        body,
        #viewDiv {
            padding: 0;
            margin: 0;
            height: 100%;
            width: 100%;
            overflow: hidden;
        .esri-zoom {
            display: none;
    </style>
    <script src="https://js.arcgis.com/4.24/"></script>
    <script>
        require([
            "esri/views/MapView",
            "esri/Map",
            "esri/layers/FeatureLayer",
            "esri/layers/MapImageLayer",
"esri/layers/TileLayer",
"esri/layers/support/TileInfo",
"esri/Basemap",
            "esri/widgets/LayerList",
            "esri/widgets/Print",
            MapView,
            Map,
            FeatureLayer,
            MapImageLayer,
TileLayer,
TileInfo,
Basemap,
            LayerList,
            Print
baseLayer = new TileLayer({
//baseLayer.maxScale = 0;
  basemap = new Basemap({
      baseLayers: [baseLayer ],
      title:"base_map",
            const map = new Map({
           // basemap: "topo-vector",// basemap
basemap: basemap
            const view = new MapView({
                container: "viewDiv",
                map: map,
//center: [0,0],
center: [-82.4645, 35.46453],
        constraints: {
rotationEnabled: false,
           lods: TileInfo.create({
             spatialReference: {
            wkid: 3857
   numLODs: 10,
           }).lods
zoom: 9,
            const featureLayer = new FeatureLayer({
               // listMode: "hide"
            const mapImageLayer = new MapImageLayer({
            map.add(featureLayer);
            //map.add(mapImageLayer);
try{
            view.when(() => {
                const print = new Print({
                    view: view,
                    printServiceUrl:
                const layerList = new LayerList({
                    view: view
                view.ui.add(print, "top-right");
                view.ui.add(layerList, "top-left");
catch(e){
console.log("Error is " + e);
    </script>
</head>
<body class="calcite">
    <div id="viewDiv"></div>
</body>
</html>
Above code prints empty pdf which has basemap tile layer, any reason or any suggestions?
