Hi, I'm trying to print a map using "esri/dijit/Print" I am adding a DynamicServiceLayer to a base map. When I click on the print button it flashes then nothing happens. I added a few handlers. print-start fires, print-complete does NOT fire, error does NOT fire. So the print starts but does not complete or does not throw an error.
I did try adding the layer as a FeatureLayer: I was able to print the base however the added feature layer did not print despite it being visible.
Map Service is located on ArcGIS Server 10.3.1 What am I missing?
here is how I add dynamic layer:
app.map = new Map("map", {
basemap: "streets",
center: [-117.42330, 47.751103],
zoom: 18
var roadLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://igis.spokanecounty.org/arcgis/rest/services/Engineering/ENGINEERINGqueries/MapServer", {
visible: true
app.map.addLayers([roadLayer]);
roadLayer.on("load", function () { });
roadLayer.setVisibleLayers([68]);
Here is print Dijit
app.printUrl = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%2...";
app.printer = new Print({
"map": app.map,
"templates": [{
label: "Map",
format: "PDF",
layout: "MAP_ONLY",
exportOptions: {
width: 500,
height: 400,
dpi: 96
label: "Layout",
format: "PDF",
layout: "A4 Portrait",
layoutOptions: {
titleText: "My Print",
authorText: "esri",
copyrightText: "My Company",
scalebarUnit: "Miles",
url: app.printUrl
dom.byId("print_button"));
app.printer.startup();
app.printer.on('error', function (evt) {
alert('The url to the print image is : ' + evt.result.url);
app.printer.on('print-complete', function (evt) {
app.printer.on('print-start', function (evt) {
alert('started');
