Geometry service is the way to go. Here's an example:<!doctype html>
<html lang="en">
<head>
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
<title></title>
<link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.4/js/dojo/dijit/themes/tundra/tundra.css">
<style>
html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
#map{ margin: 0; padding: 0; }
#info {
position: absolute;
top: 10px;
right: 10px;
width: 160px;
height: 80px;
z-index: 40;
background: #fff;
padding: 5px;
color: #000;
font-family: arial;
#results { color: red; }
</style>
<script>var dojoConfig = { parseOnLoad: true };</script>
<script src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.4"></script>
<script>
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("esri.map");
dojo.require("esri.tasks.geometry");
var map, resizeTimer, gsvc;
function init() {
var initExtent = new esri.geometry.Extent({"xmin":13410892.167988224,"ymin":394170.65114215855,"xmax":13413646.353547676,"ymax":395793.8403501995,"spatialReference":{"wkt":"PROJCS[\"NAD_1983_StatePlane_Michigan_South_FIPS_2113_IntlFeet\",GEOGCS[\"GCS_North_American_1983\",DATUM[\"D_North_American_1983\",SPHEROID[\"GRS_1980\",6378137.0,298.257222101]],PRIMEM[\"Greenwich\",0.0],UNIT[\"Degree\",0.0174532925199433]],PROJECTION[\"Lambert_Conformal_Conic\"],PARAMETER[\"False_Easting\",13123359.58005249],PARAMETER[\"False_Northing\",0.0],PARAMETER[\"Central_Meridian\",-84.36666666666666],PARAMETER[\"Standard_Parallel_1\",42.1],PARAMETER[\"Standard_Parallel_2\",43.66666666666666],PARAMETER[\"Latitude_Of_Origin\",41.5],UNIT[\"Foot\",0.3048]]"}});
map = new esri.Map("map",{extent:initExtent});
var basemap = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/BloomfieldHillsMichigan/Parcels/MapServer");
map.addLayer(basemap);
gsvc = new esri.tasks.GeometryService("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
dojo.connect(map, 'onClick', projectPoint);
dojo.connect(map, 'onLoad', function() {
dojo.connect(dijit.byId('map'), 'resize', function() {
clearTimeout(resizeTimer);
resizeTimer = setTimeout( function() {
map.resize();
map.reposition();
}, 500);
function projectPoint(evt) {
// console.log(evt.mapPoint);
map.graphics.clear();
map.graphics.add(new esri.Graphic(
evt.mapPoint,
new esri.symbol.SimpleMarkerSymbol()
var outSR = new esri.SpatialReference({ wkid: 102113});
gsvc.project([evt.mapPoint], outSR, function(result) {
// console.log('success: ', result);
dojo.byId('results').innerHTML = result[0].x.toFixed() +
', ' + result[0].y.toFixed();
dojo.ready(init);
</script>
</head>
<body class="tundra">
<div data-dojo-type="dijit.layout.BorderContainer"
data-dojo-props="design:'headline',gutters:false"
style="width: 100%; height: 100%; margin: 0;">
<div id="map"
data-dojo-type="dijit.layout.ContentPane"
data-dojo-props="region:'center'">
<div id="info">
<div id="instructions">Click the map to convert the click point to Web Mercator.</div>
<div id="results"></div>
</div>
</div>
</div>
</body>
</html>
Don't let the well-known text in the initial extent's spatial reference throw you off, it works the same if you use a WKID.
