Publishing Image service and raster function
3734
13
07-05-2016 05:46 AM
AndžejMiloš
I have published a raster as Image service and want to display it on the map using Arcgis api 4.0. Color of pixel should depend on raster cell value, exactly as in this example: ImageryLayer - Set a client side pixel filter | ArcGIS API for JavaScript 4.0
Image service is published here: AISData/CONTAINER_2013_04_test (ImageServer) and it has
Min Values: 0
Max Values: 421
But when I replace Image service with mine in example's source code I get values between 0 and 255. And I get 3 bands when expected to get 1 with pixel values.
I guess this issue regards this example description: "Setting the rendering rule to the None raster function gives the user the ability to get the actual value of the pixel (the sea temperature) without it being altered by another raster function or rendering rule."
I also guess that None raster function is not available in my Image service, because I receive javascript Error:
ImageLayerView2D.js:6 Error: {"error":{"code":400,"message":"Unable to complete operation.","details":["Do not allow execution of client function."]}}
    at Error (native)
    at .<anonymous> (http://js.arcgis.com/4.0/esri/layers/support/Raster.js:6:218)
    at f (https://js.arcgis.com/4.0/init.js:150:21)
    at p (https://js.arcgis.com/4.0/init.js:149:331)
    at resolve.callback (https://js.arcgis.com/4.0/init.js:151:151)
    at https://js.arcgis.com/4.0/init.js:325:198
    at e (https://js.arcgis.com/4.0/init.js:153:423)
    at f (https://js.arcgis.com/4.0/init.js:153:349)
    at b.resolve (https://js.arcgis.com/4.0/init.js:155:406)
    at c (https://js.arcgis.com/4.0/init.js:154:287)
How can I solve this issue?
FC_Basson
MVP Regular Contributor
Yes in that case a mosaic published as an Image Service is the only option if you want to apply raster functions.
AndžejMiloš
Thank you for your help.
Then I skip requirement 3 and try to implement 1 and 2 with Mapservice as you suggested.
With version of JSAPI 3 I used ArcGISDynamicMapServiceLayer to display Mapservice. Should I use MapImageLayer to use Identify task in version 4?
FC_Basson
Yes that should work for 4.0.  The pixel value is returned as field "Pixel Value".
AndžejMiloš
Pixel Identification on MapImageLayer works. Thank you.
