I have a service on a file geodatabase that I query using the javascript API. The query works fine in IE but fails with NS_ERROR_XPC_NOT_ENOUGH_ARGS on Firefox. The stack trace from firebug is below.
A. Anyone else have problems with firefox vs ie using esri.tasks.QueryTask and esri.tasks.Query?
B. How do you debug into dojo so you can see where the problem actually occurs?
C. Any settings or addons that could affect this?
The query is returning polygon geometry for 200-300 features with no problem for IE8.
Thanks in advance for any help or insight into this.
Brad
asyncError = [Exception... "Not enough arguments" nsresult: "0x80570001 (NS_ERROR_XPC_NOT_ENOUGH_ARGS)" location: "JS frame :: http://myhost:8080/CWServiceRequest/Scripts/csrcode.js :: anonymous :: line 143" data: no] { message="Not enough arguments", result=2153185281, more...}
toString()arcgis?v=2.1 (line 14)
constructor(err=[Exception... "Not enough arguments" nsresult: "0x80570001 (NS_ERROR_XPC_NOT_ENOUGH_ARGS)" location: "JS frame :: http://myhost:8080/CWServiceRequest/Scripts/csrcode.js :: anonymous :: line 143" data: no] { message="Not enough arguments", result=2153185281, more...}, _758=undefined)arcgis?v=2.1 (line 48)
err = [Exception... "Not enough arguments" nsresult: "0x80570001 (NS_ERROR_XPC_NOT_ENOUGH_ARGS)" location: "JS frame :: http://myhost:8080/CWServiceRequest/Scripts/csrcode.js :: anonymous :: line 143" data: no] { message="Not enough arguments", result=2153185281, more...}
_758 = undefined
constructor(_954=undefined, io=undefined, _955=undefined, _956=undefined)arcgis?v=2.1 (line 48)
_954 = undefined
io = undefined
_955 = undefined
_956 = undefined
constructor(r=Object { displayFieldName="FAC_NAME", fieldAliases={...}, more...}, i=Object { args={...}, url="http://boigiscw02/arcgi...oScript2._jsonpCallback", more...})arcgis?v=2.1 (line 48)
constructor(_1d0=Object { displayFieldName="FAC_NAME", fieldAliases={...}, more...}, io=Object { args={...}, url="http://boigiscw02/arcgi...oScript2._jsonpCallback", more...})arcgis?v=2.1 (line 48)
toString(_2b4=Object { displayFieldName="FAC_NAME", fieldAliases={...}, more...})arcgis?v=2.1 (line 14)
toString(_143=Object { displayFieldName="FAC_NAME", fieldAliases={...}, more...})arcgis?v=2.1 (line 14)
toString(_149=Object { displayFieldName="FAC_NAME", fieldAliases={...}, more...})arcgis?v=2.1 (line 14)
toString(_143=Object { promise={...}, ioArgs={...}, more...})arcgis?v=2.1 (line 14)
toString(_149=Object { promise={...}, ioArgs={...}, more...})arcgis?v=2.1 (line 14)
constructor(dfd=Object { promise={...}, ioArgs={...}, more...})arcgis?v=2.1 (line 48)
myns.queryFacilities = function () {
var myQueryTask = new esri.tasks.QueryTask(myns.basemapURL + "/" + myns.facilityLayerID.toString() );
var myQuery = new esri.tasks.Query();
myQuery.where = "AMS_FacID is not null";
myQuery.outFields = ['AMS_FacID', 'FAC_NAME']; //, 'LLat', 'LLong'];
myQuery.returnGeometry = true;
dojo.connect (myQueryTask, "onComplete", myns.facilityQuerySuccess);
dojo.connect (myQueryTask, "onError", myns.facilityQueryError);
myQueryTask.execute(myQuery);
