Is it possible to reassign the map object to another div on the page ?
var map = new esri.Map('mapone');
so my map object is created with type esri.Map and attached to the div with id 'mapone'
I would like to do at some point something like this in my code
map.reattach('maptwo');
where 'maptwo' is the id of another div. (I madeup the reattach method, but something like tis is what I am looking for) so that now my map will show in div 'maptwo'
This should be all you need. Check out DOJO's samples and tutorials if you need any other help. Make sure you mark this thread as answered if you are satisfied. Thanks!
