Refresh FeatureTable after adding feature.
5293
6
03-06-2015 10:27 AM
KeithGerhartz1
Occasional Contributor II
How would one refresh a Javascript FeatureTable digit after adding or updating a feature in the underlying FeatureTable?
DeryckMills
New Contributor II
I'd also be interested in getting this answered.
DeryckMills
New Contributor II
Keith -
Did you get an answer for this?  I've been trying to resolve it for a couple of days.
KeithGerhartz1
No answer. Sorry. I ended up ditching it in favor of using dGrid.
DeryckMills
New Contributor II
Ok thanks.  I'm leaning that way also.
AndyWright
Hi Keith,
I stumbled on some code in one of the Esri samples that works for refreshing a FeatureTable.  I would have thought this would be a method call on the FeatureTable itself, but anyway.  You basically need to destroy the div that contains your feature table and then recreate it on the fly.  It's working like a charm for me.  The outageDiv referenced below is the parent div of the div that contains the FeatureTable.
if (registry.byId("outageTableNode")) {
                        registry.byId("outageTableNode").destroy();
                        domConstruct.create("div", { id: "outageTableNode" }, dom.byId("outageDiv"));
                        console.log("re-creating table");
NMWater
New Contributor III
Did you guys ever resolve this issue? I'm trying to get the feature table to refresh after changing the visibility of the feature layer.
