I am trying to write my own widget to log-in to ArcGIS Online, and i am able to get the token back but i am never able to register the token with the identity manager so that i can pull down all of the users' content to view. when i try to query the user i get back no results, when i look at the network activity in chrome i see that the search url does not have the token in it, so i tried manually copying that search link into a new tab and manually putting the token in the request URL and i was about to get my results back, but when i try to put the token string in the query parameters which does include the token string in the request URL it tells me that i have an invalid token...but if i right click the URL with the "invalid token" and open it in a new tab it works...im baffled and the methods on the documentation dont work....does anyone else have any experience or any idea on what to do?
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
<script type="text/javascript">
var path_location = location.pathname.replace(/\/[^/]+$/, '');
var dojoConfig = {
parseOnLoad: true,
async : true
</script>
<script type="text/javascript" src="http://js.arcgis.com/3.7/">
</script>
<script>
var userLogin;
require(["esri/IdentityManagerBase",
"dojo/parser",
"esri/kernel",
"esri/urlUtils",
"esri/arcgis/utils",
"dojo/dom",
"esri/IdentityManager",
"esri/arcgis/Portal",
"dojo/domReady!"
function(IdentityManagerBase,
parser,
kernel,
urlUtils,
arcgisUtils,
dom,
IdentityManager,
Portal
var _username;
var _password;
var tokenStr;
var expireStr;
userLogin = function()
_username = document.getElementById("user").value;
_password = document.getElementById("pass").value;
var request = esri.request({
url: "https://www.arcgis.com/sharing/rest/generateToken",
content: {
request: "generateToken",
username: _username,
password: _password,
referer : "http://www.arcgis.com",
f: "json"
handleAs: "json",
load: tokenObtained,
error: tokenRequestFailed
}, {usePost : true});
function tokenObtained(response)
tokenStr = response.token;
expireStr = response.expires;
var token = {
"server": "https://www.arcgis.com/sharing/rest",
"userId": _username,
"token": tokenStr,
"ssl": true,
"expires": expireStr
esri.id.registerToken(
{server: "https://www.arcgis.com/sharing/rest/",
userId: _username,
token: tokenStr,
expires: expireStr,
ssl: true
//esri.id.registerToken(token);
// kernel.id.registerToken(token);
//console.log("token: ",token);
displayItems();
//console.log("token: ",tokenStr);
//"https://www.arcgis.com/sharing/rest/content/items/181dd71358454befae312bb01801b3ab/data?f=json&token="+tokenStr
function tokenRequestFailed(response)
console.log("in TORF", response);
function displayItems() {
queryPortal(_username);
function queryPortal(portalUser) {
var portal = new Portal.Portal("https://www.arcgis.com/");
//dojo.connect(portal, 'onLoad', loadPortal);
//var user = portal.getPortalUser();
//See list of valid item types here: http://www.arcgis.com/apidocs/rest/index.html?itemtypes.html
//See search reference here: http://www.arcgis.com/apidocs/rest/index.html?searchreference.html
//function loadPortal() {
var queryParams = {
//token: tokenStr,
q: "owner:" + portalUser, //+" AND (type: Feature Service OR type: Map Service)" ,
sortField: "numViews",
sortOrder: "desc",
num: 20
portal.queryItems(queryParams).then(createGallery);
function createGallery(items) {
var htmlFragment = "";
arrayUtils.forEach(items.results, function(item) {
htmlFragment += (
"<div class=\"esri-item-container\">" +
item.thumbnailUrl ?
"<div class=\"esri-image\" style=\"background-image:url(" + item.thumbnailUrl + ");\"></div>" :
"<div class=\"esri-image esri-null-image\">Thumbnail not available</div>"
item.title ?
"<div class=\"esri-title\">" + (item.title || "") + "</div>" :
"<div class=\"esri-title esri-null-title\">Title not available</div>"
"</div>"
dom.byId("itemGallery").innerHTML = htmlFragment;
</script>
</head>
<body>
<h2>Sign-in to ArcGIS Online</h2>
Username: <input name="username" id="user" size="27" type="text" />
<br />
Password: <input name="password" id="pass" size="27" type="password" />
<br />
<input type="button" name="action_login" value="Sign-in" onclick="userLogin()" />
</body>
</html>
