Hello, I am using the latest API version and it seems like there are some changes so the previous questions and posts are not helping me solve this problem.
I am trying to lookup an address by clicking on the map but I keep getting:
locator.locationToAddress is not a function
Below is my code, I tried to console.log(locator) and I do not see any methods, I'm not sure if I am creating the Locator object properly
this.view.on("click", event =>{
this.view.graphics.removeAll();
var point = {
type: "point", // autocasts as new Point()
longitude: event.mapPoint.longitude,
latitude: event.mapPoint.latitude,
var markerSymbol = {
type: "simple-marker", // autocasts as new SimpleMarkerSymbol()
color: [226, 119, 40]
var pointGraphic = new Graphic({
geometry: point,
symbol: markerSymbol
this.view.graphics.add(pointGraphic);
console.log("errr");
var locator = new Locator({
url: "https://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer"
console.log(locator);
locator.locationToAddress({location: event.mapPoint}).then(function(response){
console.log(response);
this.clickedOnMap(event);
In the same file above this I am using esri-loader with Reactjs and I load the modules using
loadModules(["esri/Map", "esri/views/MapView", "esri/widgets/Search", "esri/Graphic", "esri/geometry/Point", "esri/tasks/Locator", "esri/geometry/SpatialReference", "esri/geometry/support/webMercatorUtils"], { css: true })
.then(([ArcGISMap, MapView, Search, Graphic, Locator, SpatialReference, webMercatorUtils, Point]) => {
SNIP
I hope someone would be able to help me with this.
Thanks
