Hi all,
I am using ArcGIS Javascript 4.0 API and want to manually write the rotate function. The function simply add camera.heading by 5 degree after cloning the camera out and then assign it back to the original view.camera. The function is triggered by pressing a button. The rotation runs smoothly when tilt is < 90 degree. However, when it is > 90 degree, something strange happen. The heading will dramatically increase and tilt will go back to < 90 degree. May I know whether it is a bug or configuration issue?
Attached please find the excel for the testing.
Thanks a lot!
