<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7" /> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Toggle Layers, Identify Only Visible Layers </title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.4/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.4/js/esri/dijit/css/Popup.css"> <link type="text/css" href="http://ajax.googleapis.com/ajax/libs/jqueryui/1.8.2/themes/redmond/jquery.ui.all.css" rel="Stylesheet" /> <style> #slider{ width:155px; height:8px; border:1px solid #999; margin-top: 5px; margin-bottom:15px; } </style> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.6"></script> <script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.7/jquery.min.js"></script> <script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jqueryui/1.8.2/jquery-ui.min.js"></script> <script type="text/javascript"> dojo.require("esri.map"); dojo.require("esri.dijit.Popup"); var layer, map, visible = []; var identifyTask, identifyParams; $(document).ready(function(){ $("#slider").slider({ value:100, min:0, max:100, step:5, slide : function(evt, ui){ dynlayer.setOpacity(parseFloat(ui.value/100)); } }); }); function init() { //setup the popup window var popup = new esri.dijit.Popup({ fillSymbol: new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.25])) }, dojo.create("div")); var initialExtent = new esri.geometry.Extent({"xmin":-8513951.985121,"ymin":4786968.660565,"xmax":-8248256.864588,"ymax":4996406.126118,"spatialReference":{"wkid":102100}}); // var initialExtent = new esri.geometry.Extent(-9571474.89, 4592552, -9502681, 4638414, new esri.SpatialReference({ // wkid: 102100 // })); map = new esri.Map("map", { extent: initialExtent, infoWindow: popup }); dojo.place(popup.domNode, map.root); dojo.connect(map, "onLoad", function(map) { initIdentify(map); }); // Attach an onclick listener for each check box. // Update layer visiblity when each is checked clicked. var checkBoxes = dojo.query('input[type=checkbox]'); dojo.forEach(checkBoxes, function(cb) { dojo.connect(cb, 'onclick', updateDynLayerVisibility); }); var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/Canvas/World_Light_Gray_Base/MapServer"); map.addLayer(basemap); //Use the ImageParameters to set the visible layers in the map service during ArcGISDynamicMapServiceLayer construction. var imageParameters = new esri.layers.ImageParameters(); imageParameters.layerIds = [0,1,2,3]; imageParameters.layerOption = esri.layers.ImageParameters.LAYER_OPTION_SHOW; //can also be: LAYER_OPTION_EXCLUDE, LAYER_OPTION_HIDE, LAYER_OPTION_INCLUDE dynlayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://gis.dvrpc.org/ArcGIS/rest/services/TCDI/MapServer", { "imageParameters": imageParameters }); map.addLayer(dynlayer); } function initIdentify(map) { dojo.connect(map, "onClick", executeIdentifyTask); //create identify tasks and setup parameters identifyTask = new esri.tasks.IdentifyTask("http://gis.dvrpc.org/ArcGIS/rest/services/TCDI/MapServer"); identifyParams = new esri.tasks.IdentifyParameters(); identifyParams.tolerance = 12; identifyParams.returnGeometry = true; // identifyParams.layerIds = [0,1,2,3]; identifyParams.layerIds = dynlayer.visibleLayers; identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL; identifyParams.width = map.width; identifyParams.height = map.height; } function updateDynLayerVisibility() { var inputs = dojo.query(".dyn_item"); visible = []; for (var i = 0, il = inputs.length; i < il; i++) { if (inputs.checked) { visible.push(inputs.id); } } // If no layers are visible set the array value to = -1 // and disconnect the identify task if (visible.length === 0) { visible = [-1]; map.infoWindow.hide(); } // Update Identifys layers identifyParams.layerIds = visible; // Update layer visiblity dynlayer.setVisibleLayers(visible); } function executeIdentifyTask(evt) { if (visible.length === 1 && visible[0] == -1){ map.infoWindow.clearFeatures(); map.infoWindow.show(evt.mapPoint); } else { identifyParams.geometry = evt.mapPoint; identifyParams.mapExtent = map.extent; var deferred = identifyTask.execute(identifyParams); deferred.addCallback(function (response) { // response is an array of identify result objects // return an array of features. return dojo.map(response, function (result) { var feature = result.feature; feature.attributes.layerName = result.layerName; if (result.layerName === 'Year 2002'){ var template = new esri.dijit.PopupTemplate({ title: "<FONT color=#CB2F27><B>{PROJECTNAM}</B></FONT>", description: "<B>Location:</B>{MUN_NAME}, {CO_NAME} County, {STATE}<br>" +"<B>Amount: </B>{AMT_WEB}<br>" +"<B>Year Awarded: </B>{YR}<br>" +"<B>Project Number: </B>{PROJECTNUM}<br>" +"<B>Project Type: </B>{PROJECTTYP}<br>" +"<B>Project Description: </B>{PROJ_DESC}{PROJ_DESC2}{PROJ_DESC3}{PROJ_DESC4}", mediaInfos: [{ "title": "study area", "caption": "click for larger image", "type": "image", "value": { "sourceURL": "{PHOTO_TH}", "linkURL": "{PHOTO}" } }] }); feature.setInfoTemplate(template); } else if (result.layerName === 'Year 2003'){ var template = new esri.dijit.PopupTemplate({ title: "<FONT color=#F0BD56><B>{PROJECTNAM}</B></FONT>", description: "<B>Location:</B>{MUN_NAME}, {CO_NAME} County, {STATE}<br>" +"<B>Amount: </B>{AMT_WEB}<br>" +"<B>Year Awarded: </B>{YR}<br>" +"<B>Project Number: </B>{PROJECTNUM}<br>" +"<B>Project Type: </B>{PROJECTTYP}<br>" +"<B>Project Description: </B>{PROJ_DESC}{PROJ_DESC2}{PROJ_DESC3}{PROJ_DESC4}", mediaInfos: [{ "title": "study area", "caption": "click for larger image", "type": "image", "value": { "sourceURL": "{PHOTO_TH}", "linkURL": "{PHOTO}" } }] }); feature.setInfoTemplate(template); } return feature; }); }); map.infoWindow.setFeatures([deferred]); map.infoWindow.show(evt.mapPoint); } } dojo.addOnLoad(init); </script> </head> <body class="claro"> <div> Layers: <br /> <input type='checkbox' class='dyn_item' checked='checked' id='0' />Year 2002<br /> <input type='checkbox' class='dyn_item' checked='checked' id='1' />Year 2003<br /> Opacity:<br/> <div id="slider"> </div> </div> <div id="map" style="width:1200px; height:600px; border:1px solid #000;"></div> </body> </html>
Solved! Go to Solution.
Ben,
Thanks for the reply. Option 2 is the way I was thinking of going for this project but wanted to poke around a bit before.
Great explanation on the API, map domNode and image retrieval as well. sometimes I forgot to think about that stuff when I'm wrapped up in a project.
