Once I've added them I want to zoom to my map with the wkid 4326.
I'm adding the layers map.addLayers([backgroundMapLayer, LinkedMap]); // map.addLayers([102748 , 4326]);
What should I be using to the map extent. I've tried using the linkedMap full exent min/max xy coordinate and wkid of 102746. I've also tried to set it to background min/max xy coordinate and wkid of 4326 I've then tried to zoom the map and get the whole world ( I can manually zoom and center and see my map layer over the base map in the correct place) or 0,0 off of Africa.
If someone could explain to me what I should be setting my initial map extent so when I run map.setZoom or map.centerAndZoom(map.getLayer("baseLayer").fullExtent.getCenter(), 5) it zooms to where my map I'd appreciate it.
I'm believe I'm missing how I reconcile the different wkid.
