I have a map on which some analysis is done. At the end of the analysis, the user is able to generate a report. The report manifests in a separate browser window. I send the information for the report via a query string. I would like the selected feature to also show up selected on the report map. Can I serialize the graphic selection object to put in the query string and deserialized on the report map? Is there another, better, way to show the selected graphic on the report map?
Paige
