<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/esri/css/esri.css"> <script src="http://js.arcgis.com/3.6/"></script> <title>Routing</title> <style> html, body, #map{ height: 100%; margin: 0; padding: 0; } </style> <script> var map, serviceAreaTask, params, routeparams, routeTask; require([ "dojo/_base/Color", "esri/map", "esri/graphic", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/tasks/FeatureSet", "esri/tasks/RouteTask", "esri/tasks/RouteParameters", "esri/tasks/RouteResult", "dojo/domReady!" ], function (Color, Map, Graphic, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol, FeatureSet, RouteTask, RouteParameters, RouteResult) { esriConfig.defaults.io.proxyUrl = "/proxy"; map = Map("map", { basemap: "streets", center: [-86.18, 40.22], zoom: 16 }); map.on("solvecomplete", showRoute); routeparams = new RouteParameters(); routeparams.attributeParameterValues = [{attributeName: "Time", parameterName: "10 MPH", value: "10"}]; routeparams.outSpatialReference = map.SpatialReference; routeparams.returnRoutes = true; routeparams.returnStops = true; routeTask = new RouteTask("http://tasks.arcgisonline.com/ArcGIS/rest/services/NetworkAnalysis/ESRI_Route_NA/NAServer/Route"); function showRoute(evt) { map.graphics.clear(); var stopSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CROSS, 3, new SimpleLineSymbol( SimpleLineSymbol.STYLE_SOLID, new Color([89, 95, 35]), 2 ), new Color([130, 159, 83, 0.40]) ); routeparams.stops.features.push(map.graphics.add(new Graphic(evt.mapPoint,stopSymbol))); routeTask.solve(routeparams, function (solveRoute) { var lineRoute = new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASH, new Color([254,0,0]),3); dojo.forEach(solveRoute.routeResults, function (routeResult) { routeResult.setSymbol(lineRoute); map.graphics.add(routeResult); }); }); } }); </script> </head> <body class="claro"> <div id="map"></div> </body> </html>
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Basic Service Area with Slider</title> <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/esri/css/esri.css"> <style> body,html,#main{margin:0;padding:0;height:100%;width:100%;} </style> <script>var dojoConfig = { parseOnLoad: true };</script> <script src="http://js.arcgis.com/3.7/"></script> <script> dojo.require("esri.map"); dojo.require("esri.tasks.servicearea"); dojo.require("dijit.dijit"); dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("dijit.form.HorizontalSlider"); dojo.require("dijit.form.HorizontalRuleLabels"); dojo.require("dijit.form.HorizontalRule"); var map, serviceAreaTask, params, clickpoint; function init() { //This sample requires a proxy page to handle communications with the ArcGIS Server services. You will need to //replace the url below with the location of a proxy on your machine. See the 'Using the proxy page' help topic //for details on setting up a proxy page. esri.config.defaults.io.proxyUrl = "/proxy"; map = new esri.Map("map", { basemap: "streets", center: [-122.447, 37.781], zoom: 15 }); dojo.connect(map, "onClick", mapClickHandler); params = new esri.tasks.ServiceAreaParameters(); params.defaultBreaks= [1]; params.outSpatialReference = map.spatialReference; params.returnFacilities = false; params.outputLines = esri.tasks.NAOutputLine.TRUE_SHAPE; serviceAreaTask = new esri.tasks.ServiceAreaTask("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Network/USA/NAServer/Service Area"); dojo.connect(dijit.byId("hslider"), "onChange", updateHorizontalLabel); updateHorizontalLabel(); } // Create function that updates label when changed function updateHorizontalLabel() { // Get access to nodes/widgets we need to get/set values var hSlider = dijit.byId("hslider"); var label = dojo.byId("decValue"); // Update label label.innerHTML = hSlider.get("value"); params.defaultBreaks = [hSlider.value/60]; if (typeof clickpoint != 'undefined') { mapClickHandler(clickpoint); }; } function mapClickHandler(evt) { clickpoint = evt; map.graphics.clear(); //clear existing graphics //define the symbology used to display the results and input point var pointSymbol = new esri.symbol.SimpleMarkerSymbol( esri.symbol.SimpleMarkerSymbol.STYLE_DIAMOND, 20, new esri.symbol.SimpleLineSymbol( esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([88,116,152]), 2 ), new dojo.Color([88,116,152,0.45]) ); var inPoint = new esri.geometry.Point(evt.mapPoint.x,evt.mapPoint.y,map.spatialReference); var location = new esri.Graphic(inPoint,pointSymbol); map.graphics.add(location); var features = []; features.push(location); var facilities = new esri.tasks.FeatureSet(); facilities.features = features; params.facilities = facilities; //solve serviceAreaTask.solve(params,function(solveResult){ var result = solveResult; var serviceAreaSymbol = new esri.symbol.SimpleFillSymbol( esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol( esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([232,104,80]), 2 ), new dojo.Color([232,104,80,0.25]) ); var polygonSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([232,104,80]), 2),new dojo.Color([232,104,80,0.25])); dojo.forEach(solveResult.serviceAreaPolygons, function(serviceArea){ serviceArea.setSymbol(polygonSymbol); map.graphics.add(serviceArea); }); dojo.forEach(solveResult.serviceAreaPolylines, function(g) { var outline = new esri.symbol.SimpleLineSymbol().setWidth(2); g.setSymbol(outline); map.graphics.add(g); } ); },function(err){ console.log(err.message); }); } dojo.ready(init); </script> </head> <body class="claro"> <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width:100%;height:100%;margin:0px;"> <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'top'"> <b>Click to find the service area polygon</b> <div style="width: 400px; margin: 10px"> <!-- create rules and labels above horizontal slider --> <ol data-dojo-type="dijit.form.HorizontalRuleLabels" data-dojo-props=" container: 'topDecoration', style: 'height: 1.2em; font-weight: bold; margin: 0 12px;'"> <li>0</li> <li>0:20</li> <li>0:40</li> <li>1:00</li> <li>1:20</li> <li>1:40</li> <li>2:00</li> </ol> <div data-dojo-type="dijit.form.HorizontalRule" data-dojo-props=" container: 'topDecoration', count: 7, style: 'height: 5px; margin: 0 12px;'"> </div> <input id="hslider" value="60" type="range" data-dojo-type="dijit.form.HorizontalSlider" data-dojo-props=" minimum: 0, maximum: 120, showButtons: false, discreteValues: 25"> <div style="padding-top: 10px; text-align: center;">Travel time: <strong id="decValue"></strong> seconds</div> </div> </div> <div id="map" dojotype="dijit.layout.ContentPane" data-dojo-props="region:'center'"></div> </div> </body> </html>
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10"/> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/dojo/dijit/themes/claro/claro.css"/> <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/esri/css/esri.css"/> <script src="http://js.arcgis.com/3.6/" type="text/javascript"></script> <title>Routing</title> <style type="text/css"> html, body, #map { height: 100%; margin: 0; padding: 0; } </style> <script type="text/javascript"> var map, serviceAreaTask, params, routeparams, routeTask; require([ "dojo/_base/Color", "esri/map", "esri/graphic", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/tasks/FeatureSet", "esri/tasks/RouteTask", "esri/tasks/RouteParameters", "esri/tasks/RouteResult", "dojo/domReady!" ], function (Color, Map, Graphic, SimpleMarkerSymbol, SimpleLineSymbol, FeatureSet, RouteTask, RouteParameters, RouteResult) { //esriConfig.defaults.io.proxyUrl = "/proxy"; map = Map("map", { basemap: "streets", center: [-86.18, 40.22], zoom: 16 }); routeparams = new RouteParameters(); routeparams.attributeParameterValues = [{ attributeName: "Time", parameterName: "Speed class 13", value: "10"}]; routeparams.outSpatialReference = map.SpatialReference; routeparams.returnRoutes = true; routeparams.returnStops = true; routeparams.stops = new FeatureSet(); routeTask = new RouteTask("http://tasks.arcgisonline.com/ArcGIS/rest/services/NetworkAnalysis/ESRI_Route_NA/NAServer/Route"); map.on("click", showRoute); function showRoute(evt) { console.log("click"); //map.graphics.clear(); var stopSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CROSS, 20, new SimpleLineSymbol( SimpleLineSymbol.STYLE_SOLID, new Color([89, 95, 35]), 2 ), new Color([130, 159, 83, 0.40]) ); var g = new Graphic(evt.mapPoint, stopSymbol); map.graphics.add(g); routeparams.stops.features.push(g); if (map.graphics.graphics.length != 2) { return; } routeTask.solve(routeparams, function (solveRoute) { var lineRoute = new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASH, new Color([254, 0, 0]), 3); dojo.forEach(solveRoute.routeResults, function (routeResult) { var g = routeResult.route; g.setSymbol(lineRoute); map.graphics.add(g); }); }); } }); </script> </head> <body class="claro"> <div id="map"> </div> </body> </html>
I have fixed a lot of errors. Now you can continue on this code ...<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10"/> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/dojo/dijit/themes/claro/claro.css"/> <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/esri/css/esri.css"/> <script src="http://js.arcgis.com/3.6/" type="text/javascript"></script> <title>Routing</title> <style type="text/css"> html, body, #map { height: 100%; margin: 0; padding: 0; } </style> <script type="text/javascript"> var map, serviceAreaTask, params, routeparams, routeTask; require([ "dojo/_base/Color", "esri/map", "esri/graphic", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/tasks/FeatureSet", "esri/tasks/RouteTask", "esri/tasks/RouteParameters", "esri/tasks/RouteResult", "dojo/domReady!" ], function (Color, Map, Graphic, SimpleMarkerSymbol, SimpleLineSymbol, FeatureSet, RouteTask, RouteParameters, RouteResult) { //esriConfig.defaults.io.proxyUrl = "/proxy"; map = Map("map", { basemap: "streets", center: [-86.18, 40.22], zoom: 16 }); routeparams = new RouteParameters(); routeparams.attributeParameterValues = [{ attributeName: "Time", parameterName: "Speed class 13", value: "10"}]; routeparams.outSpatialReference = map.SpatialReference; routeparams.returnRoutes = true; routeparams.returnStops = true; routeparams.stops = new FeatureSet(); routeTask = new RouteTask("http://tasks.arcgisonline.com/ArcGIS/rest/services/NetworkAnalysis/ESRI_Route_NA/NAServer/Route"); map.on("click", showRoute); function showRoute(evt) { console.log("click"); //map.graphics.clear(); var stopSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CROSS, 20, new SimpleLineSymbol( SimpleLineSymbol.STYLE_SOLID, new Color([89, 95, 35]), 2 ), new Color([130, 159, 83, 0.40]) ); var g = new Graphic(evt.mapPoint, stopSymbol); map.graphics.add(g); routeparams.stops.features.push(g); if (map.graphics.graphics.length != 2) { return; } routeTask.solve(routeparams, function (solveRoute) { var lineRoute = new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASH, new Color([254, 0, 0]), 3); dojo.forEach(solveRoute.routeResults, function (routeResult) { var g = routeResult.route; g.setSymbol(lineRoute); map.graphics.add(g); }); }); } }); </script> </head> <body class="claro"> <div id="map"> </div> </body> </html>
