The key-down event invalid in zoom out when using ARCGIS JavaScript in EPSG:3826
321
12-25-2023 10:42 PM
AbramhumHsu
New Contributor III
Hi:
I am a newbie to ARCGIS JAVASCRIPT. And I meet a problem when the tileLayer load in, and the zoom controller I set in the top-right is not work well. The plus button can only be invoked event two or three times,  and then not working any more, and the minus button can work well. In another aspect of moues, the mouse-wheel event can zoom out/in in perfect behavior.  my version is 4.10, my environment is node.js with express, the code snippet is as following:
const basemap = new Basemap({
baseLayers: [
new TileLayer({
url: "https://arcgis.tpgos.gov.taipei/arcgis/rest/services/ED/GD_Plain_Service/MapServer",
title: "Basemap",
crossOrigin: 'anonymous',
spatialReference: {
wkid: 102443
title: "basemap",
spatialReference: {
wkid: 102443
// Create a map using the MapImageLayer
var map = new Map({
basemap: basemap
var view = new MapView({
container: "divmap",
map: map,
zoom: 3,
extent: {
xmin: 296938.73458000005,
ymin: 2776832.77203,
xmax: 301876.2566600001,
ymax: 2781271.34259,
spatialReference: {
wkid: 102443
} // Set the spatial reference
//spatialReference: { wkid: 102100 } // Set the spatial reference
view.ui.move("zoom", "top-right");
is anyone know the exactly reason? and how to fix that, thanks a lot.
UndralBatsukh
Hi there,
You need to specify the spatialReference for the view's extent as the following:
  map: map,
  zoom: 3,
  extent: {
    spatialReference: {
      wkid: 102443
  spatialReference: {
    wkid: 102443
UndralBatsukh
Hi there,
  map: map,
  zoom: 3,
  extent: {
    spatialReference: {
      wkid: 102443
  spatialReference: {
    wkid: 102443
